Can Fourier Series Solve a Discontinuous Heat Problem on a One-Dimensional Rod?
  • Thread starter Thread starter nicksauce
    Pde Weird
The discussion focuses on solving a discontinuous heat problem modeled by the equation ∂U/∂t = (1/4)∂²U/∂x² - 12[U - 8x]. The initial condition (IC) U(x,0) = 3x and boundary conditions (BCs) U(0,t) = 0 and U(2,t) = 2t present a conflict, as U(2,0) yields different values from the IC and BCs. The recommended approach is to utilize a Fourier series solution by redefining the function as V(x,t) = U(x,t) - 2t, allowing for homogeneous boundary conditions suitable for a Fourier sine series solution.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with Fourier series and their applications
  • Knowledge of boundary and initial conditions in mathematical modeling
  • Basic concepts of heat transfer in one-dimensional systems
  • Study the application of Fourier sine series in solving PDEs
  • Research techniques for handling discontinuities in heat equations
  • Explore the method of separation of variables for PDEs
  • Learn about the implications of homogeneous vs. non-homogeneous boundary conditions
Mathematicians, physicists, and engineers working on heat transfer problems, particularly those dealing with partial differential equations and Fourier analysis.
nicksauce
The question is:
Write a short paragraph that physical problem modeled by the equation:
[tex] \frac{\partial{U}}{\partial{t}} = \frac{1}{4}\frac{\partial^2{U}}{\partial^2{x}} -12[U - 8x][/tex]
Subject to
IC: U(x,0) = 3x
BCs: U(0,t) =0, u(2,t) = 2t
Okay so clearly, the physical problem is some kind of heat problem with a one dimensional rod and a heat source term. However, the problem is that the IC and the BCs are conflicting, since U(2,0) = 6, from the IC, but U(2,0) = 0 from the BC. Any advice to go about answering this?
What that means is that your function is not continuous. That's alright if you are using integration techniques which will "smooth" the discontinuity. I would recommend using a Fourier series solution. In fact, I would write V(x,t)= U(x,t)- 2t and solve the problme for V so that the boundary conditions are "homogeneous" and you can use a Fourier sine series.
