| Thread Closed |
Work on a sliding Block |
Share Thread | Thread Tools |
| Oct1-07, 04:28 AM | #1 |
A block of weight w sits on a frictionless inclined plane, which makes an angle (theta) with respect to the horizontal. A force of magnitude F, applied parallel to the incline, pulls the block up the plane at constant speed. 1)The block moves a distance up the incline. The block does not stop after moving this distance but continues to move with constant speed. What is the total work Wtot done on the block by all forces? (Include only the work done after the block has started moving, not the work needed to start the block moving from rest.) 2)What is Wg, the work done on the block by the force of gravity as the block moves a distance up the incline? 2. Relevant equations Wtot = the sum of all work factors right ? So I have to find the work from the force going up the ramp, the work from gravity. ?? 3. The attempt at a solution I think the answer to q1 is W-tot = FL + (-wsin(theta))+N (The opposite force of mg = w) But this is not correct but I don't know why? Anyone? |
| Oct1-07, 01:53 PM | #2 |
Recognitions:
For the total work, what does the work energy theorem say?
for work done by gravity, use work = [tex]\vec{F}\cdot\vec{d}[/tex] |
| Oct10-07, 09:33 PM | #3 |
love how i got Wgravity wrong...
Wf= -mgcos(theta) * L (from masteringphysics, your answer is off by a multiplactive factor..) |
| Oct10-07, 09:44 PM | #4 |
Recognitions:
Work on a sliding BlockWf = mgsin(theta)*L F must be mgsin(theta) acting up the plane. |
| Oct10-07, 09:46 PM | #5 |
sorry i meant force done by gravity
| Oct10-07, 09:48 PM | #6 |
Recognitions:
| Oct10-07, 09:49 PM | #7 |
that's exactly what i put....
but masteringphysics says i'm off by a multiplactive factor,, |
| Oct10-07, 10:07 PM | #8 |
Recognitions:
| Oct10-07, 10:56 PM | #9 |
thank you
my fault ... i input -wgsin(theta)*L |
| Oct10-07, 11:25 PM | #10 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: Work on a sliding Block
| Sliding Block | Introductory Physics Homework | 3 | ||
| Sliding Ice Block | Introductory Physics Homework | 2 | ||
| A block sliding down an incline | Introductory Physics Homework | 2 | ||
| sliding block | Introductory Physics Homework | 3 | ||
| Sliding Block Problem | Introductory Physics Homework | 5 | ||
