Heat Capacity of Air at Constant Volume
The discussion revolves around the heat capacity of air at constant volume, particularly in the context of compressing a specific volume of air into a smaller tank. Participants are exploring the implications of heat capacity ratios and the characteristics of gases under compression.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants are attempting to clarify the heat capacity of air at constant volume and its relationship to the heat capacity at constant pressure. Questions about the measurement of gas and the implications of the heat capacity ratio are also raised.
There is an ongoing exploration of the concepts related to heat capacity, with some participants providing numerical values and ratios while others question the independence of heat capacity from volume for ideal gases. Guidance on the relationship between specific heats and the need to calculate the number of moles is also present.
Participants mention constraints such as a lack of references and the original poster's background in archaeology rather than physics, which may limit their access to resources for clarification.
s.p.q.r
Hi
I have an ongoing dispute with my mate on this one, please help to clarify this before I open up a can of whoop ass on that sorry mo-fo.
300 litres of air are compressed into a 3 litre tank. What is the heat capacity of this air?
Thanks in advance.
What do you think it is?
The Cp J mol is 29.19. But because I ask for constant volume, it is definitely lower then this. This is what I think. I can find no references to constant volume anywhere and unfortunately I have no teacher to ask as I study archaeology, not physics.
Do you have the answer?
Thanks in advance.
Do you have the answer?Thanks in advance.
Air is almost entirely a diatomic gas, [itex]\gamma = C_p/C_v = 1.4[/itex] (7/5)
AM
Hi,
Thanks for the reply. Is 1.4 per gram or mol?
Also,
How can you measure a gram of gas and how much is 1 mol?
Cheers.
Is heat capacity independent of volume for an ideal gas?
Stupid question - gas performs work while being compressed.
For an ideal gas heat capcity just depends on the amount (number of moles) present and the number of vibration states of the molecular.
For a real gas it also depends on the pressure because the molecules close to each other change the vibration state/bond energy.
In a modification of the "ideal gas" law, I seem to recall an equation with correction terms for the volume and pressure, respectively. Has anyone run across this?
Hi,
This ratio of 1.4, does this just mean that you divide the constant pressure capacity (1.020J/g) by 1.4?
s.p.q.r said:
Hi,
[itex]\gamma = 1.4[/itex] is the ratio of the specific heat (heat flow per gram or per mole per degree K change in temperature) at constant pressure to the specific heat at constant volume. [itex]\gamma = C_p/C_v[/itex]. What you want to find is Cv. You also have to find the number of moles of air in this container to find its heat capacity (heat flow per degree K change in Temp.).
AM
  • · Replies 61 ·
  • · Replies 31 ·
