Subset Relationships between Sets of Functions: U, A, B, C, D, E, F
  • Thread starter Thread starter Steverino777
The problem involves analyzing the relationships between various sets of functions defined by specific properties, such as continuity, differentiability, and polynomial characteristics. The sets in question are U, A, B, C, D, E, and F, each representing different criteria for functions with real domains and ranges.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants discuss the relationships between the sets, particularly focusing on the implications of differentiability and continuity. There is an exploration of specific examples of functions to clarify which sets may be subsets of others. Some participants question the definitions and properties of the sets, while others suggest writing out equations to better visualize the relationships.
There is an ongoing exploration of the subset relationships among the sets, with some participants providing insights and examples to support their reasoning. While some conclusions are being drawn, there is still uncertainty and a lack of consensus on several points, indicating that the discussion is productive but not yet resolved.
Participants are working within the constraints of homework guidelines, which may limit the amount of direct assistance they can receive. There is also a focus on understanding the properties of functions rather than simply listing subset relationships.
Steverino777
Let U be the set of all functions having R as domain and range a subset of R:
A={f|f is continuous at each x ∈ R}
B={f|f is differentiable at each x ∈ R}
C={f|f '(x) = 2x + 3 for each x ∈ R}
D={f|f is a quadratic polynomial}
E={f|f(0) = 0}
F={f|f is a linear polynomial}
List all subset relationships between pairs of these 6 sets.
A is a subset of B when every element of A is also and element of B.
I'm having a hard time visualizing all these sets and being able to compare their elements. One thing I know from calc: If f is differentiable; then f is continuous. However, if f is continuous, it doesn't mean that f is necessarily differentiable. So I'm assuming A ⊆ B or B ⊆ A, I just don't know which way it is.
I also know that every set is a subset of itself.
So those are probally the easy answers, I'm having trouble relating the rest of them. If anyone could help me out, that would be great.
A is a subset of B when every element of A is also an element of B.
Let f be an element of A. Is f also an element of B?
Let g be an element of B. Is g also an element of A?
For C through F, writing out the equations might help. E.g., what does the "characteristic" element of D look like?
What would be some elements of a? Would they be like equations? If i knew some examples of elements of each equation then I could determine myself probally which are subsets of which.
Hmm. Enuma's help was sufficient but I will show you how to do one.
Let's investigate E and F. All the elements of E have the property that f(0)=0, so what kind of functions are these? There's lots of them! For example, there's sin(x) and there's 2x. It should be fairly easy to see that any sum or scalar multiple of an element of E is also in E (prove it) so we can generate more elements than you could ever count.
But is E a subset of F? If it was that would mean that every element in E is also in F. We know that sin(x) is in E but it is obviously not in F, as F is the set of functions that can be written as f(x)=ax+b.
Now you have 14 other possibilities to check.
Please write back if you're encountering difficulties.
Alright what you said, makes a lot of sense. I'm still have some trouble grasping all of this though. I think I know a few answers though, hopefully you can tell me if these are right.
For C f '(x)= 2x+3. That would mean f(x)=x^2 + 3x. This is a qudratic polynomial so I would assume then C ⊆ D. This is also cont. and diff so C ⊆ A and C ⊆ B.
I'm also thinking since all qudratic and linear polynomials (i hope) are cont and diff then, D ⊆ A, D ⊆ B, F ⊆ A, F⊆ B.
Also all diff. functions are cont. so B ⊆ A.
So maybe I'm doing this completely wrong, but I'd appreciate if you could tell me how my answers are. Thank you very much for the help so far.
