Can you swim in melted dry ice?
  • Thread starter Thread starter photon
    Dry ice Ice
The discussion revolves around the properties of dry ice, specifically whether it can be melted into a liquid form suitable for swimming without getting wet. Participants explore the nature of dry ice, its sublimation process, and the conditions under which it might become liquid.
  • One participant questions if swimming in melted dry ice is possible and what makes dry ice "dry."
  • Another participant explains that dry ice can turn into liquid under sufficient pressure and warmth, but this would result in getting wet.
  • It is noted that dry ice is solid carbon dioxide and sublimates directly into gas rather than melting into a liquid.
  • Participants discuss the density of liquid carbon dioxide and the conditions required for it to liquefy, mentioning specific pressures and temperatures.
  • There is a humorous exchange regarding the toxicity of CO2 and its implications for hypothetical plans of world domination.
  • A warning is provided about the dangers of CO2 in enclosed spaces and the need for proper ventilation when handling dry ice.
Participants generally agree on the properties of dry ice and its sublimation process, but there is no consensus on the feasibility of swimming in melted dry ice, as the concept itself is speculative and humorous.
Some assumptions about the conditions required for liquefying dry ice and the implications of CO2 toxicity are not fully explored, leaving room for further discussion.
photon
If I melt dry ice, can I swim without getting wet?
I'm just curious: What makes dry ice dry?
Short answer: if you put enough pressure on dry ice, and then warm it up, it will turn liquid--and it would very definitely get you wet, if your body could stand the pressure.
Dry ice is dry because it contains no water -- it is solid carbon dioxide. It does not melt into a liquid; it sublimates directly into gaseous C02.
- Warren
It is fun stuff! Dry ice expands about 800 times from its solid volume to its gasseous volume at STP. Just another fun fact, the temperature of it is around -109.3 F (-78.5 C).
Check out www.dryiceinfo.com for more info than you probably want.
The density of water is around 62.4 LB/FT³ The link provided by Macgiver says the density of liquid carbon dioxide is 63.69 LB/FT³ and its triple point is -69 Fahrenheit and 75.1 PSIA. So if you put about 5 atmospheres of pressue on it, you can get it to liquify at -69 degrees.
So is that what all the white gas is that is emitted from dry ice? Just CO2?
Shucks. There goes my plan for world domination. :mad: :biggrin:
Don't give up on the world domination plans just yet -- CO2 is in fact very toxic. :biggrin:
- Warren
Maybe so, but I'll need a better name for it. Like "Super Killer Inhaling Stuff."
Please be careful. Discharging a fire extinguisher to put out a fire can displace the air in an enclosed area and lead to you to becoming disoriented or unconscious.
Do not transport large quantities of dry ice in your car without proper ventilation.
-Mike
