* Using Lorentz transform to find velocity of rod
The discussion focuses on using the Lorentz transformation to determine the velocity of a rod moving towards an observer in an inertial reference frame S. The observer notes the proper length of the rod, denoted as l, and the time T it takes for the rod to pass. The coordinates for event E2, when the tail end of the rod passes the observer, are established as (x,t)=(0,T) for frame S and (0,gamma*T) for the rod's rest frame S'. The key to solving for the rod's velocity lies in applying the Lorentz transformation equations correctly.
  • Understanding of Lorentz transformation equations
  • Knowledge of proper length and time dilation concepts
  • Familiarity with inertial reference frames in physics
  • Basic grasp of event coordinates in spacetime
  • Study the derivation and application of Lorentz transformation equations
  • Learn about time dilation and its implications in special relativity
  • Explore the concept of simultaneity in different reference frames
  • Practice solving problems involving velocity calculations using Lorentz transformations
Students of physics, particularly those studying special relativity, as well as educators and anyone needing to apply Lorentz transformations in practical scenarios.
Odyssey
URGENT* Using Lorentz transform to find velocity of rod
a person at the origin of an inertial reference frame S observes a rod of proper length l moving towards him at a speed v. He notes that the rod takes a time T to pass him. Assuing that when the front end of the rod passes the observer, the clocks in S and in the rest frame S' of the rod are both set to read zero. Using Lorentz transformation, establish a relation between the coordinates of event E2 to find the velocity of the rod. E2 is when the tail end of the rod passes the observer at the origin S.
The lorentz transformation equations...and its inverse perhaps?
I think I identified the coordinates alright...here they are (I hope):
T is the proper time measured by S, so for E2, S measures (x,t)=(0,T).
Time is dilated for S' (rest frame of moving rod), so for him E2 is at (0,gamma*T)
So now I have to use the Lorentz tranformation...but how...? to solve for the velocity of the rod...in terms of l...and T...?
Thanks for the help in advance...I greatly appreciate it. Assignment is due VERY soon. Friend said he was going to help me but didn't. :(
It x' = 0 for E2? Note: You want to set x'=0 for E1.
Once you've correctly written (x,t) and (x',t') for E2, what invariance can you use to relate these quantities?
  • · Replies 101 ·
  • · Replies 55 ·
