How Is Total Kinetic Energy Calculated for a Rolling Cylinder?
The discussion revolves around calculating the total kinetic energy of a rolling cylindrical log as it descends a ramp. Participants explore the relationship between translational and rotational kinetic energy, as well as the influence of height on energy calculations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the necessary information for calculating kinetic energy, including the log's speed and height. There are inquiries about the implications of missing height data and how it affects energy calculations. Some participants suggest using energy conservation principles to relate potential energy to kinetic energy.
Several participants have provided insights into the calculations, including the use of equations for both translational and rotational kinetic energy. There is an ongoing exploration of different scenarios, such as comparing a cylinder to a sphere, and questions about the transition between these cases. No consensus has been reached on the final answers, but productive dialogue continues.
Participants note that the problem lacks specific height information initially, which is crucial for determining potential energy. There are also discussions about the assumptions made regarding the shape of the object and its impact on the calculations.
psruler
Can someone help me with this problem:
A cylindrical wooden log rolls (without slipping) down a smal ramp. Tha log has radius of 15 cm, a length of 2.0m and a mass of 85kg.
What was the log's TOTAL kinetic energy at the bottom of the ramp? (Recall that Icylinder = (1/2)MR^2) .
The total angular velocity i got was 200 rad/s.
I don't know if the angular velocity will help solve the problem.
THANKS!
Not enough information. How high is the log on the ramp?
cookiemonster
Well, that is the next question I have to solve. That's all the information. Is there a way of solving this problem if the height is not given?
No. The energy is determined by the height, since the only energy the log has at first is gravitational potential energy, which depends on height.
cookiemonster
The previous question states that the log rolls at a speed of 3.0m/s when it reaches the bottom of the ramp.
Well now you have enough information!
The total KE is the sum of (1) translational KE of the center of mass (1/2MV2), and (2) rotational KE about center of mass(1/2Iω2). Since the log rolls without slipping, V =ωR.
Thanks Doc Al!
Then can I find the height using this equation:
h = v^2/2g ?
Find the height using energy conservation. The initial gravitational PE at the top gets transformed into the total KE at the bottom.
h = v^2/2g ?
No because the log also has rotational KE (1/2Iω2), not just translational KE.
The answer i got is: 0.62m. Can you verify if that is correct?
I get a total kinetic energy of 573.75J at the bottom and a height of 6.75/g. So if you take g to be 10.9m/s2 it's right. :wink:
how did you get 6.75 as the height?
I get a (slightly) different answer. Maybe we should average them all together? :wink:
Show us the equations you used, what numbers you assumed, and how you calculated the answer. (Show it algebraically first, then with numbers plugged in.)
I got:
[tex]mgh = 573.75J[/tex]
So:
[tex]h = \frac{573.75J}{mg} = \frac{6.75}{g}[/tex]
My equation:
[tex]mgh = \frac{1}{2}mv^2 + \frac{1}{2}I\omega ^2 = \frac{1}{2}mv^2 + \frac{1}{4}mr^2\omega ^2 = \frac{3}{4}mv^2[/tex]
[tex]h = \frac{3v^2}{4g}[/tex]
I agree, of course. (I misread your answer, Chen, like psruler did. :rolleyes: )
I have a question now. Let's say it is a sphere now, instead of a cylinder. The equation would be:
[tex]mgh = \frac{1}{2}mv^2 + \frac{1}{2}I\omega ^2 = \frac{1}{2}mv^2 + \frac{1}{5}mr^2\omega ^2 = \frac{7}{10}mv^2[/tex]
[tex]v^2 = \frac{10gh}{7}[/tex]
But now let's take that sphere and reduce its radius until it tends to zero (so we find ourselves with a "point" particle). Obviously the mass and the radius of the object do not affect the speed it would reach at the bottom of the hill, as that only depends on the height of it. So on one hand, we know that for point particles there is no such thing as rotational kinetic energy, so the speed squared would be 2gh. However, if we do count the rotational KE we find the speed squrared to be of 10gh/7. So which answer is the correct one? And where's the limit between a point particle and a sphere? i.e when in the process of reducing the object's radius will the speed change from one expression to the other?
An excellent question!
Chen said:
... So on one hand, we know that for point particles there is no such thing as rotational kinetic energy, so the speed squared would be 10gh/7. However, if we do count the rotational KE we find the speed squrared to be of 2gh. So which answer is the correct one? And where's the limit between a point particle and a sphere? i.e when in the process of reducing the object's radius will the speed change from one expression to the other?
This is an excellent question, Chen! (I think you have the cases mixed, though.) I think when you reach that limit, the normal analysis of static friction causing rotation will break down. Surface effects will dominate.
  • · Replies 21 ·
  • · Replies 32 ·
