Forming differential equationsfrom words to formula
The problem involves forming a differential equation based on the rate of increase of ice thickness on a pond, which is stated to be inversely proportional to the thickness already present. The scenario includes specific conditions regarding temperature and thickness, leading to a request for a differential equation and an analysis of the time taken for a specific thickness increase.
  • Mixed
  • Participants discuss the relationship between the rate of increase and the thickness of ice, with some attempting to derive the differential equation from the given conditions. There is confusion regarding the proportionality and the correct formulation of the equation.
Several participants are exploring different interpretations of the problem, particularly the nature of the proportionality involved. Some have offered clarifications and pointed out potential errors in reasoning, while others are questioning the assumptions made about the relationship between rate and thickness.
There is mention of missing information and the challenge of having multiple constants with limited data. Participants are also addressing the implications of the problem's wording on their understanding of the mathematical relationships involved.
rock.freak667
The rate of increase of thickness of ice on a pond is inversely proportional ro the thickness of ice already present. It is known that,when the thickness is x cm and the temperature is of the air above the ice is -a degrees celsius, the rate is [itex]\frac{ax}{14400} cms^{-1}[/itex] . Form an appropriate diff. eq'n and show that, if the air temp is -10 degrees Cel. , the time taken for the thickness to increase from 5 com to 6 cm is a little more than 2 hours
"The rate of increase of thickness of ice on a pond is inversely proportional or the thickness of ice already present."
[tex]\frac{dx}{dt} \alpha x => \frac{dx}{dt}=kx[/tex]
therefore [tex]lnx=Ae^{kt}[/tex] and that looks wrong as I have yet to use the given rate...I am confused about the thickness and the given rate
How do you get [tex]\frac{dx}{dt} \alpha x => \frac{dx}{dt}=kx[/tex]? Is that really inversely proportional?
The rate at a given point is merely there so you can determine your constant.
oh my bad..i did the question wrong.supposed to be [tex]x^2=Kt+C[/tex]..but I only have one piece of info and 2 constants 'a' and 'k'
You've missed a factor of a half. What you do know is that:
[tex]\frac{dx}{dt}=kx=\frac{ax}{14400} cms^{-1}[/tex] at some thickness x and temperature -a degrees C.
I multiplied through out by 2..2k=K and 2c=C ...so then k=a/14400 and then sub that in the eq'n
And you have missed the point that EnumaElish raised: the rate is inversely proportional to the thickness, not directly proportional. Assuming x is the thickness of the ice at time t (I personally would insist upon that being explicitely stated), then
[tex]\frac{dx}{dt}= \frac{k}{x}[/tex]
That gives a whole different situation!
Argh! I apologise. I did this myself at 3 am and was just about to post that he hadn't written it inversely proportional when enuma elish beat me to it, then I go and make the same mistake. Can't believe I did that. Anyway sorry to the OP for any confusion.
  • · Replies 30 ·
9K
12K
11K
