Solve Calculus Derivative: Step-by-Step Guide for f'(3x-6)/x
  • Thread starter Thread starter Cmunro
    Derivative
The discussion revolves around finding the derivative of the function f' (3x-6)/x, a topic within calculus. Participants are exploring different methods to approach the differentiation of this expression.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss breaking down the fraction and applying different rules of differentiation, such as the Quotient Rule and Product Rule. There are questions about the steps taken and the reasoning behind them.
The discussion is active, with participants sharing their thought processes and methods. Some guidance has been offered regarding alternative approaches to the problem, and there is acknowledgment of the potential for multiple valid methods leading to the same result.
One participant notes that they may not have covered the Quotient Rule yet, indicating a possible gap in knowledge that could affect their approach to the problem.
Cmunro
Hi,
I am just starting out in calculus, and I'm not sure how to work through this type of question:
f' [tex]\frac{3x-6}{x}[/tex]
So I have:
(3x-6)(x[tex]^{-1}[/tex])
then (3x -6)(-x[tex]^{-2}[/tex])
Now what?
(3)(-x[tex]^{-2}[/tex])?
The book gives an answer of 6(x[tex]^{-2}[/tex])
Thanks in advance
The first thing id probably do is break down that fraction into [tex]3-\frac{6}{x} = 3 - 6x^{-1}[/tex] and then work from there.
Aha, got it, thank you!
Cmunro said:
Hi,
So I have:
I'm guessing you haven't gotten to the Quotient Rule yet. When you have, you'll see that you could also work this out using that (and you'll get the same answer), but you won't get the result you have on your last line here...
You could also use the Product Rule on your expression
(3x-6)(x[tex]^{-1}[/tex]), which would give you two terms, the one you found:
plus a second term
(3x-6)' · (x[tex]^{-1}[/tex]) = 3 · (x[tex]^{-1}[/tex]) ,
adding up to (3x -6-3x)(-x[tex]^{-2}[/tex]) = 6/(x[tex]^{-2}[/tex]) .
All three methods, the one you ultimately used and these two, give the same answer.
  • · Replies 25 ·
  • · Replies 24 ·
