Finding Velocity of Top of Object's Shadow
  • Thread starter Thread starter bdb1324
    Shadow Velocity
The problem involves a light source, an opaque object, and a vertical wall, focusing on finding the velocity of the top of the object's shadow as the object moves toward the wall. The context includes concepts from geometry and similar triangles.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the relationships between the dimensions of the triangles formed by the light source, the object, and the shadow. Questions arise regarding the expressions for height and distance, particularly the interpretation of v*t and its relation to the height of the shadow.
The discussion is active, with participants exploring different interpretations of the geometric relationships involved. Some guidance has been offered regarding the use of similar triangles, but there is no explicit consensus on the correct approach or formula at this stage.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is an emphasis on understanding the relationships rather than reaching a final solution.
bdb1324
A small source of light S is located at a distance L from a vertical wall. An opaque object with a height of h moves toward the wall with constant velocity v_vec of magnitude v. At time t= 0 , the object is located at the source S.
Find an expression for v_s, the magnitude of the velocity v_s_vec of the top of the object's shadow, at time t.
Express the speed of the top of the object's shadow in terms of t, v, L, and h
it is a similar triangle problem
I figured out that v*t gives me H
So i thought that since it was a similar triangle
I could use (v*t*L)/h to find the v_s
How do you get that v*t is h?
no since they are similar triangles and v/t is the starting point of h than the larger triangle must be v*t
how are you getting v/t ?
The small triangle has sides v*t, h and the hypoteneuse.
The big triangle has sides L, s(height of the shadow) and the hypoteneuse.
isn't v/t the initial starting point of the wall and to get the furthest distance the wall is away wouldn't that be v*t
thanks I got it. It was the same problem. (L*h)/vt^2
15K
  • · Replies 25 ·
