Register to reply
Elastic collision question: two marbles
by GFWD
Tags: collision, elastic, marbles
Share this thread:
GFWD
#1
Oct3-07, 01:19 PM
P: 1
I just want to know if I am approaching this question correctly.
Two marble spheres of masses 30 and 20 grams, respectively, are suspended from the ceiling by massless strings (.95m long). The lighter sphere is pulled aside through an angle of 75 degrees and let go. It swings and collides elastically with the other sphere at the bottom of the swing.
a) To what maximum angle will the heavier sphere swing.
b) To what maximum angle will the lighter sphere swing.
2. Relevant equations
Conservation of mechanical energy
Conservation of momentum
Conservation of kinetic energy
3. The attempt at a solution
1. Calculate the height the small sphere is above the "rest" state. Use this height and conservation of mechanical energy to get the velocity.
2. Use conservation of momentum and conservation of kinetic energy to get the velocity of the larger and smaller spheres after the collision.
3. Use conservation of mechanical energy to get the new heights of the large and small sphere.
4. use trig to get the angles of each sphere.
Does that approach make sense?
Thanks.
Phys.Org News Partner Science news on Phys.org
Physical constant is constant even in strong gravitational fields
Montreal VR headset team turns to crowdfunding for Totem
Researchers study vital 'on/off switches' that control when bacteria turn deadly
Astronuc
#2
Oct3-07, 04:55 PM
Admin
Astronuc's Avatar
P: 21,915
That approach will work.
Here are some useful references -
http://hyperphysics.phy-astr.gsu.edu/hbase/elacol.html
http://hyperphysics.phy-astr.gsu.edu/hbase/colsta.html
Register to reply
Related Discussions
Question on impulse, does it assume elastic collision? Introductory Physics Homework 1
Elastic Collision - Symbolic Question Introductory Physics Homework 3
Elastic Collision question Introductory Physics Homework 4
Elastic collision General Physics 3
Elastic collision? General Physics 3
