Gravity and Photon Relationship: Understanding Red and Blue Shift
  • Context: Graduate
  • Thread starter Thread starter journeytospace
    Gravity Photon
The discussion centers around the relationship between gravity and photons, specifically addressing the phenomenon of redshift and blueshift in the context of photons escaping a gravitational field. Participants explore theoretical explanations and interpretations of the relevant equations, including the implications of gravitational effects on photon frequency.
  • One participant cites a formula from Hyperphysics suggesting that as a photon escapes a gravitational field, its frequency increases, potentially indicating a blueshift.
  • Another participant proposes two explanations for the observed redshift: one involving the conservation of total energy (kinetic and potential) and the other relating to the energy levels of atoms emitting photons in a gravitational field.
  • A different participant challenges the interpretation of the formula, arguing that as the radial distance increases, the term in the formula decreases, leading to an increase in the overall frequency, thus supporting the idea of a blueshift.
  • Another participant clarifies that the formula describes the frequency of a photon emitted at a specific gravitational potential and observed at a distance, indicating that it is redshifted when observed from afar.
Participants express differing interpretations of the gravitational effects on photon frequency, with no consensus reached on whether the escaping photon experiences a blueshift or redshift. Multiple competing views remain regarding the correct interpretation of the relevant equations and concepts.
Participants reference specific equations and theoretical frameworks, but there are unresolved assumptions regarding the definitions of energy and frequency in gravitational contexts. The discussion does not resolve the mathematical implications of the formula presented.
journeytospace
hi...I read from Hyperphysics site the relation between gravity and photon which says that
When the photon escapes the gravity field, it will have a different frequency
f ′= f (1 - GM/r*c²)...so when photon escapes r increases and so the value in the bracket also increases and hence frequency would be increasing which means it would be blue shifted when photon escapes gravitational field then why we say that light from a gravitational field would be red shifted ..is this right? Please clarify...
There are two alternative ways to explain the red shift of photons in the gravitational field.
First explanation. One can imagine that the photon, like a massive particle, has both kinetic (K) and potential (V) energy, so that the total energy E = K + V remains constant while the photon is moving in the gravitational field. Then, when the photons moves away from Earth its potential energy V increases and kinetic energy K decreases, so that the frequency (assumed to be proportional to the kinetic energy) goes down as well. So, the red shift is the result of the photon's attraction to the massive body.
Second explanation. Photons are emitted in transitions between energy levels of atoms, nuclei, etc. For atoms deep in the gravitational field the separations between their energy levels decrease. Therefore, photons emitted by such atoms have lower energy. This energy doesn't change while the photon is traveling in the field. So, the red shift occurs because atoms emitting the photons are attracted to the massive body.
These two approaches were discussed in
L.B. Okun, K.G. Selivanov, V.L. Telegdi, "On the Interpretation of the Redshift in a Static Gravitational Field" http://www.arxiv.org/abs/physics/9907017
where it was concluded that the second explanation is actually correct.
I can also add the following argument against the first explanation. When the photon is registered by a detector it is absorbed completely. So, its total energy gets released in the detector. Therefore, its measured frequency should be proportional to the total energy E (which does not depend on the position of the photon in the gravitational field) rather than its kinetic energy K.
Eugene.
You've made a mistake in intrpreting the forumula f ′= f (1 - GM/r*c²). As r increases then the quantity GM/r*c² starts to decrease and not increase. As GM/r*c² decreases there is less and less to subtract from 1. Therefore the term (1 - GM/r*c²) is increasing and thus so is f'
Pete
thank you...i mean value of the bracket as a whole increases and so frequency increases so there should be blue shift right...
I think what the formula you quoted is referring to is a photon emitted at frequency f at Schwarzschild radial parameter r. It is observed by a distant observer (at r -> infinity, in free space) as frequency f ′, which is lower than f and hence redshifted. This equation does not track the observed frequency of a photon over changing observer distances.
  • · Replies 46 ·
  • · Replies 132 ·
9K
  • · Replies 17 ·
  • · Replies 33 ·
  • · Replies 30 ·
  • · Replies 67 ·
  • · Replies 55 ·
