Vector Calc - Directional Derivative Question
The discussion focuses on finding the curve along which Igor, the inchworm, should travel to minimize the intensity of a magnetic field defined by M(x,y) = 4x² + y² + 5000 at the point (8,6). The gradient of the field is calculated as <8x, 2y>, yielding a specific gradient vector of <64, 12> at the given point. To minimize field intensity, Igor must move in the opposite direction of the gradient, leading to the differential equation dy/dx = (1/4)(y/x). This equation can be solved using separation of variables to derive the curve y³ = 27x towards the origin.
  • Understanding of vector calculus, specifically gradients
  • Familiarity with differential equations and separable equations
  • Knowledge of magnetic field intensity concepts
  • Proficiency in calculus techniques for integration
  • Study the method of solving separable differential equations
  • Explore applications of gradients in optimization problems
  • Learn about magnetic field calculations in physics
  • Investigate the relationship between vector fields and curves in multivariable calculus
Students and educators in mathematics and physics, particularly those studying vector calculus and differential equations, as well as anyone interested in optimization techniques in multivariable contexts.
at3rg0
Igor, the inchworm, is crawling along graph paper in a magnetic field. The intensity of the field at the point (x,y) is given by M(x,y) = 4x^2 + y^2 + 5000. If Igor is at the point (8,6), describe the curve along which he should travel if he wishes to reduce the field intensity as rapidly as possible.
Gradient M = <8x, 2y>
To minimize, one must travel opposite the gradient
I got the gradient as <8x, 2y> (just the partial derivatives as a vector). Also, at (8,6), the gradient is <64, 12>, which is in the direction of the unit vector 16i + 3j/sqrt(16^2 +3^2). So, the direction he wants to travel is the negative version of that vector. However, the problem wants me to arrive at the formula (y^3 = 27x towards the origin). How do I go from the vector to the curve?
This TEX is driving me crazy. If anyone can help me by editing my post, that would be great.
Thanks in advance!
You are correct that <64, 12> gives the direction he wants to go at that time. But as soon as he has moved slightly it will change. What you are saying is that he wants to move so that dx/dt= -8x and dy/dt= -2y. It's not difficult to solve both of those for x and y as functions of t but you don't need the time dependence- you only need the curve itself:
[tex]\frac{dy}{dx}= \frac{\frac{dy}{dt}}{\frac{dx}{dt}}= \frac{1}{4}\frac{y}{x}[/tex].
That's a simple separable equation. Separate the variables and integrate.
9K
