Maximizing Your Workstation: DVI to VGA Adapters
  • Thread starter Thread starter Astronuc
The discussion revolves around the use of DVI to VGA adapters in the context of setting up a workstation with a graphics card that has only DVI slots and VGA monitors. Participants explore the technical aspects of DVI and VGA compatibility, the practicality of using adapters, and the implications for workstation setup.
  • Experimental/applied
  • One participant notes the inconvenience of having a graphics card with only DVI slots when using VGA monitors and mentions the existence of DVI to VGA adapters.
  • Another participant clarifies that DVI to VGA adapters do not convert signals but rely on the presence of VGA signals on specific pins of the DVI connector, which may not be available on all graphics cards.
  • A participant mentions the cost of DVI to VGA adapters and inquires about the possibility of a dual-monitor setup.
  • A later reply indicates that the current setup does not require a dual-monitor configuration and discusses the challenges faced in finding the appropriate adapter, ultimately leading to the purchase of a DVI-I adapter instead of a new monitor.
  • The participant explains that the workstation is primarily used for simulations accessed over a LAN, negating the need for a high-end monitor.
Participants express varying levels of understanding regarding the functionality of DVI to VGA adapters, with some agreeing on their utility while others highlight potential limitations and compatibility issues. The discussion does not reach a consensus on the best approach for adapting the workstation setup.
The discussion includes assumptions about the availability of VGA signals on DVI connectors and the specific requirements for dual-monitor setups, which may not be universally applicable. There are also references to pricing and availability of adapters that may vary by location.
This discussion may be useful for individuals setting up workstations with mixed display technologies, those considering hardware purchases, or anyone interested in the technical compatibility of DVI and VGA connections.
Astronuc
Staff Emeritus
2025 Award
Just got a new high-end workstation at work, but the graphiscs card has two DVI slots (new video HD protocol) and we have only VGA monitors at the moment. The builder should have used a card (XFX) with VGA and DVI slots. But what's done is done.
Mild inconvenience.
So I quickly learned that there are such things at DVI to VGA adapters, whereby the VGA monitor plugs into the VGA (female) end, and the DVI (male) end plugs into the DVI slot on the card.
DVI monitors are a little bit more expensive. Just something to consider when purchasing a new computer.
Computer science news on Phys.org
Remember the DVI-VGA converter doesn't actaully convert DVI-VGA.
The DVI standard has optionally the VGA signals on spare pins, the four extra pins alongside the sideways blade connector.
There is no requirement for the graphics card to have the VGA signal and it is often only present on a single output. It should be labelled DVI-I if it has both DVI(digital) and VGA(analog).
DVI to VGA adapters aren't too expensive (about $15 at best buy... possibly cheaper at (say) Dell).
So, are you going to run a dual-monitor setup?
Not at the moment. There is no need. The box was constructed with a card that had two DVI slots rather than one DVI and one VGA/SVGA slot on the same card.
Since we didn't have a DVI monitor, but only VGA, I was faced this morning with having to buy a monitor, since I called a couple of nearby places and the either didn't have a DVI-I adapter or didn't know what it was. :rolleyes:
But I found a DVI-I (Belkin) adapater (not converter) at Staples, which cost $30. That saved me a $60 DVI cable and ~$240 for a DVI monitor.
The workstation is essentially a computational engine for running simulations. We access it across a LAN for I/O, so we don't need a fancy monitor. The output is further processed on other machines.
  • · Replies 16 ·
