Solve AP Calc Problem: Draining Water from Conical/Cylindrical Tanks
The problem involves the dynamics of draining water from a conical tank into a cylindrical tank, focusing on the rates of change of volume and depth of water in both tanks. The conical tank has specific dimensions, and the rate of change of water depth in the conical tank is given.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss expressing the volume of the conical tank as a function of the water depth, questioning how to eliminate the radius variable. There are attempts to derive the rate of change of volume with respect to time and to relate the changes in the conical tank to the cylindrical tank.
Participants are actively engaging with the problem, exploring different expressions for volume and discussing the relationships between variables. Some guidance has been offered regarding the use of similar triangles to relate the radius and height in the conical tank, and there is an ongoing exploration of how the rates of change in both tanks are interconnected.
There is a focus on ensuring the correct interpretation of the problem's requirements, particularly in expressing the volume function and understanding the relationships between the rates of change in the conical and cylindrical tanks. Participants are also considering the implications of the negative rate of change due to draining.
gonzalo12345
Water is drained from a conical tank with height 12ft and diameter 8ft into a cylindrical tank that has a base with area 400Π square feet. the deep, h, in feet, of the water in the conical tank is changing at the rate of 12 ft/min
a. write an expression for the volume of water int eh conical tank as a function of h
b. at what rate is the volume of water in the conical tank changing when h=3?
c. At the same time, h=3, at what rate is the radius changing?
d. let y be the depth, in feet, of the water in the cylindrical tank. at what rate is y changing when h=3?
V= 1/3Πr^2h
for a I think is just rearranging the volume equation right?, for part B I had dV/dt = 324Π, can somebody check is that is ok, and for c and d I'm lost.
Thanks in advance for all your help!
What do you mean by "rearranging"? It will help a reader if you show your calculations.
I mean that V=1/3Πr^2h
then 3V=Πr^2h
3V/Πr^2 = h
gonzalo12345 said:
I mean that V=1/3?r^2h
then 3V=?r^2h
3V/?r^2 = h
That isn't what it meant by "expressing the volume as a function of h". What they're looking for is the volume function for this cone written with h as the only variable. So you have to use some information to eliminate the variable r .
so would it be:
V= 3Πh^3
gonzalo12345 said:
so would it be:
V= 3?h^3
I don't quite agree (though I think I know what you did) -- what is r in terms of h? (If you look at the cross-section of the conical tank with water in it, you'll see that you can use similar triangles to show that the relationship remains the same for any water level.)
ok, so:
V=1/27Πh^3
gonzalo12345 said:
ok, so:
V=1/27?h^3
Much better! So how would you find (dV/dt) at the moment when h = 3 ft?
dV/dt = 3(1/27)Πh^2. dh/dt
dv/dt = 12Π
so for c do I use the same triangle relation to find dr/dt?
gonzalo12345 said:
dV/dt = 3(1/27)?h^2. dh/dt
dv/dt = 12?
Yes. (Don't forget the (ft^3)/min units on dV/dt .)
and for d, how is Dv/dt from the cone the same as Dy/dt?
The dV/dt for the cylinder will be the negative of the dV/dt for the cone, since the cylinder is being filled up.
Oh, by the way, I forgot to mention that for your calculation
dV/dt = 3(1/27)(pi)(h^2) · dh/dt
that dh/dt = -12 ft/min because that tank is being drained, so the level is decreasing and we should have
dv/dt = -12(pi) .
So dV/dt for the cylindrical tank is +12(pi) (ft^3)/min. You'll need a formula for the volume of a cylinder, so you can turn it into a rate equation. We don't know how much water is already in the tank, but that doesn't matter, since you'll be working with rates of change...
  • · Replies 56 ·
