Find equation of a parabola when neither of two points is the vertex
  • Context: Undergrad
  • Thread starter Thread starter srujana_09
    Parabola Points Vertex
The equation of a parabola can be determined when two points on the curve and the time of travel between them are known, provided that neither point is the vertex. The general form of the parabola is given by the equation y = ax² + bx + c, requiring three conditions to solve for the coefficients a, b, and c. Two conditions arise from the points (x₀, y₀) and (x₁, y₁) lying on the parabola, leading to two equations. The third condition is derived from the arc-length formula, which requires knowledge of the arc-length or uniform velocity between the two points.
  • Understanding of quadratic equations and their standard forms
  • Familiarity with calculus, specifically integration for arc-length calculation
  • Knowledge of the concept of velocity in relation to distance and time
  • Ability to manipulate algebraic equations to solve for multiple variables
  • Study the derivation and application of the arc-length formula in calculus
  • Learn how to solve systems of equations involving quadratic functions
  • Explore the concept of uniform velocity and its implications in physics
  • Investigate the properties of parabolas and their applications in real-world scenarios
Mathematicians, physics students, engineers, and anyone interested in understanding the dynamics of parabolic motion and curve fitting in mathematical modeling.
srujana_09
Can we find the equation of a parabola when two points on it and the time of travel between the two points are given.It is also given that neither of the two given points is the vertex.
If you don't know the speed, it can't be done.
Assuming that the parabola has vertical axis, then the equation can be written [itex]y= ax^2+ bx+ c[/itex]. You need three conditions to solve for the three coefficients, a, b, and c.
Saying that the given point [itex](x_0,y_0)[/itex] is on the parabola means that [itex]y_0= ax_0^2+ bx_0+ c[/itex]. Saying that the given point [itex](x_1,y_1)[/itex] is on the parabola means that [itex]y_1= ax_1^2+ bx_1+ c[/itex]. That gives you two of the three equations you need.
If [itex]y= ax^2+ bx+ c[/itex], then [itex]y'= 2ax+ b[/itex] so the arc-length between [itex]x_0[/itex] and [itex]x_1[/itex] is given by
[tex]\int_{x_0}^{x_1}\sqrt{1- (2ax+ b)^2}dx[/tex]
If you know the arc-length between the two points, you would have the third. Calculate the formula for arclength between the two points and set equal to that. Of course, if you know the "uniform velocity", the arclength is just the time divided by that velocity. If you don't know the velocity, then, as mathman said, you don't have enough information to determine the parabola.
  • · Replies 21 ·
  • · Replies 25 ·
