Thread Closed
electric dipole in an electric field
Share Thread Thread Tools
Oct5-07, 01:53 PM   #1
A small object with electrc dipole moment [tex]\overrightharpoonup{p}[/tex] is placed in a nonuniform electric field [tex]\overrightarrow{E}[/tex] =E(x)[tex]\hat{i}[/tex]. That is, the field is in the x direction and its magnitude depends on the coordinate x. Let [tex]\theta[/tex] represent the angle between the dipole moment and the x direction. (a) Prove that the net force on the dipole is F=p([tex]\frac{dE}{dx}[/tex])cos[tex]\theta[/tex] acting in the direction of the increasing field.
2. Relevant equations
U=-pEcos[tex]\theta[/tex]
p[tex]\equiv[/tex]2aq
3. The attempt at a solution
im not asking for anyone to do the problem, but I dont even know where to start. if someone could just please maybe help me understand the problem better and help me get started i would much appreciate it.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Oct5-07, 02:15 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
You have the potential U. The force is the negative of the gradient of the potential. Is that a good starting point?
Oct5-07, 03:15 PM   #3
so F=-U, so F=pE[tex]cos\theta[/tex], and (dE/dx) is the direction of the electric field as it changes with the coordinate x because the electric field is nonuniform right?
Oct5-07, 03:23 PM   #4
Recognitions:
The potential is a scalar function. It's -p.E ('.'=dot product). In your case since the directions of the vectors are fixed, you can as you have, write this as -|p||E(x)|cos(theta). So U is a function of x. F is not equal to -U. It's equal to minus the GRADIENT of U. How do you compute a gradient?
Oct5-07, 03:38 PM   #5
i just dont know. i think that it might be E=[tex]\delta[/tex]V/[tex]\delta[/tex]x
Oct5-07, 03:41 PM   #6
Recognitions:
The gradient of a function U is (dU/dx,dU/dy,dU/dz) (where the derivatives are partial derivatives).
Oct5-07, 03:57 PM   #7
im sorry, i just dont understand, i see all these equation for W(work)=U and i can see that there should be some way for me to solve this problem because as you have explained it to me, it actually seems very simple, except that i dont know how to put the gradient into the equation. i know that W=-[tex]\int[/tex]F.ds=-[tex]\int[/tex]qE.ds where F and E and ds are vectors but...im sorry
Oct5-07, 04:30 PM   #8
Recognitions:
Ok, so if W=-integral(F*ds) then dW/ds=-F. Or F=-dU/ds. Apply that to this problem. In three dimensions you want to think of a gradient rather than a simple derivative, but if that is driving you crazy, forget about it for now. Treat it as a one dimensional problem, but afterwards think about why dU/dy=0 and dU/dz=0 mean F_y=0 and F_z=0.
Oct6-07, 12:18 AM   #9
are du/dy=0 and du/dx=0 because they are perpendicular to the electric field? but i think i understand some. and since i am trying to find F_x right? then i would evaluate W=[tex]\int[/tex]pEsin[tex]\theta[/tex]-find the derivative and i would have my answer right? i worked it out except for the p part of the equation. i know that p is a constant so to find the derivative?
Oct6-07, 12:56 AM   #10
Recognitions:
I give up. Can somebody else take this post please? I really give up.
Oct6-07, 01:33 AM   #11
sorry dont bother
Oct6-07, 02:11 AM   #12
Recognitions:
Given the potential U... the force is:
[tex]\vec{F} = -\bigtriangledown{U}[/tex]
In other words: Fx = -dU/dx. Fy = -dU/dy. Fz = -dU/dz.
Once you know U, you can immediately get the force...
What is U?
As Dick mentions:
[tex]U = -\vec{p}\cdot\vec{E}[/tex]
so
[tex]U = -(pcos(\theta), psin(\theta),0)\cdot (E(x),0,0)[/tex]
so that gives [tex]U = -E(x) pcos(\theta)[/tex]
now you can directly get the components of the force using Fx = -dU/dx. Fy = -dU/dy. Fz = -dU/dz.
the important thing here is that E(x) is only a function of x... it is independent of y and z.
So you should be able to get your result directly using Fx = -dU/dx
Oct6-07, 02:30 AM   #13
thank you so much, im sorry i didnt get it before, now that you explain it, it seems so simple like i thought, i just dont know why i didnt get it before. sorry dick.
Oct6-07, 12:07 PM   #14
Recognitions:
Quote by jhess12 View Post
Sometimes having somebody else say the same thing makes all the difference. Sorry, I lost patience as well.
Thread Closed
Thread Tools
Similar Threads for: electric dipole in an electric field
Thread Forum Replies
period of an electric dipole rotating in an external electric field Introductory Physics Homework 2
Electric field of an electric dipole Introductory Physics Homework 2
Electric dipole charges/Electric Field Introductory Physics Homework 3
Electric field of a dipole Advanced Physics Homework 0
Electric field due to dipole Introductory Physics Homework 2
