Calculate Derivatives: Using Information to Find (fg)'(1) and (fog)'(1)
  • Thread starter Thread starter physstudent1
    Derivatives
The discussion revolves around calculating the derivatives of composite and product functions involving two functions, f and g, where specific values and derivatives of f at a point are provided, along with the definition of g. Participants are exploring how to apply the product and chain rules of differentiation to find (fg)'(1) and (fog)'(1).
  • Mixed
  • Participants are considering whether to multiply the derivatives of f and g or to find the derivative of the product of f and g directly. There is uncertainty about how to proceed with the second derivative without having the explicit form of f.
Some participants have clarified the notation and rules applicable to the problem, such as the product rule and chain rule. Guidance has been offered on how to approach the calculations using the known values of f and g, although there remains some confusion about the necessity of additional information regarding f.
Participants note that the problem does not provide the explicit equation for f(x), which raises questions about how to proceed with finding the derivative of the composite function without this information.
physstudent1
Suppose f and g are functions. Assume that f is differentiable and f(1) = 2, f'(1)=4 and that g(x) = x^4 -x+1. Use this information to calculate:
(fg)'(1)
(f o g)'(1)
I'm unsure of what this wants me to do Does it want me to multiply the derivatives of f and g together and calculate it at 1 or does it want me to multiply f and g then find the derivative and plug in 1.
For the 2nd one I found the derivative of g(x) to be 4x^3 -1 plugged a 1 into that and got 3 now i have f'(3) = ? how can i know that when they only gave me f(1) and f'(1) ?
I would guess that (fg)(x) means f(x) times g(x), but you should check your book or course notes or whatever is relevant for the definition you are supposed to be using.
For the second part, (f o g)(x) usually means f(g(x)), which can be differentiated by the chain rule. You should find that you do not need the value of f'(3).
Does "product rule" and "chain rule" ring a bell?
Product rule: [tex](fg)'=f'g+fg'[/tex]
and
Chain rule: [tex](f \circ g)'(x) = f'(g(x)) g'(x)[/tex]
Just a clarification of notation: [tex](f \circ g)(x)[/tex] is also written as [tex]f(g(x))[/tex] and is read as "[tex]f[/tex] of [tex]g[/tex] of [tex]x[/tex]". It simply means you first apply the [tex]g[/tex] function to [tex]x[/tex] and then the [tex]f[/tex] function to the resultant. The [tex]'[/tex] indicates the first derivative of the function.
ah ok its not (fg)x tho its (fg)'(x)
and I don't know the equation for f(x) it doesn't give it to you so how can i find the derivative of
f(x^4-x+1)
would it be
(3x^3 - 1)*(f(x^4 - x+1))
You don't need the equation for [tex]f(x)[/tex].
Ok, let's do the first one first. Start off with the product rule:
[tex](fg)'=f'g+f'[/tex] which can be written more formally as:
[tex](f(x)g(x))'=f'(x)g(x) + f(x)g'(x)[/tex]
The values of [tex]f'(1)[/tex] and [tex]f(1)[/tex] are given, and the values for [tex]g'(1)[/tex] and [tex]g(1)[/tex] can be calculated by plugging [tex]1[/tex] into the [tex]g(x)[/tex] function. And then differentiate [tex]g(x)[/tex] to find [tex]g'(1)[/tex]. Plug in the resulting values into the above equation and you will obtain your solution for the first part.
Finding the derivative of [tex]g(x)[/tex] should be quite simple.
To do the second part, similarly just plug in your knowns.
gotcha thanks
  • · Replies 26 ·
