How to Measure the Time Period of Vertical Oscillations | Exam Preparation Tips
This discussion focuses on measuring the time period of vertical oscillations in a physics experiment. The method involves timing 20 oscillations and calculating the average time to determine the period T. To achieve a percentage uncertainty of 1% in T, the formula 2x/T = 0.01 is utilized, where x represents the error in one reading. The accuracy of the timer, particularly digital timers, is noted to have a minimal error margin, typically in milliseconds.
  • Understanding of vertical oscillations and their measurement
  • Familiarity with basic statistical averaging techniques
  • Knowledge of error analysis in experimental physics
  • Experience with timing devices, particularly digital timers
  • Research the principles of oscillation and harmonic motion
  • Learn about error propagation and uncertainty analysis in experiments
  • Study the use of digital timers and their accuracy specifications
  • Explore advanced techniques for measuring oscillation periods, such as using photogates
Students preparing for physics exams, educators teaching experimental methods, and anyone interested in the practical application of oscillation measurements in physics.
MightyHound
Here is the question:
Gently displace the mass and release it so that it performs vertical oscillations. Make measurements to determine the period T of the oscillations.
So here is what I did:
Time for 20 oscillations = t1 (2 d.p)
Time for another 20 oscillations = t2 (2 d.p)
Average time for 20 oscillations = (t1 + t2)/2 (2 d.p)
Time for one oscillation, T = { (t1 + t2)/2 } / 20 ---> this is your answer correct to 1 decimal place.
Right. Next question:
Estimate the number of oscillations that would need to be timed in order to make the percentage uncertainty in T equal to 1%. Show your working.
Let error in one reading be x
So we use the formula:
2x/T = 0.01
where T = { (t1 + t2)/2 } / N (N is the number of oscillations).
We use the above formula to find out N.
Here are my concerns:
Is the working above correct for the two questions?
What on Earth is the error in timers? (for protractors it is 1deg; for rulers it is 1mm).
Thanks friends.
I am getting that heartpounding, gutwrenching, vomit inducing exam jitters right about now. Exam is only a few days away.
I am not new to the forums here - I have been an avid view for some time now.
Thanks for all your help guys!
Yes, the working above is correct for the two questions. The error in timers will depend on the accuracy of the timer you are using. Generally, if you are using a digital timer, the error should be quite small (on the order of milliseconds).
  • · Replies 26 ·
  • · Replies 17 ·
