Creating a Class in C++ 2005: Debug Report Error Analysis
  • Context: C/C++
  • Thread starter Thread starter splac6996
    Class
The discussion centers on an error encountered while using Microsoft Visual C++ 2005 to create a new class. The error message indicates a mismatch in the argument list for a function, specifically involving 'std::ostream' and 'void'. The user is advised to check the build log located at "c:\Documents and Settings\DEWAND JONES\My Documents\CSCI 1020\HOMEWORK5.2\HOMEWORK5.2\Debug\BuildLog.htm" for more detailed information. Additionally, it is noted that the user should provide their code for more accurate troubleshooting.
  • Familiarity with Microsoft Visual C++ 2005 IDE
  • Understanding of C++ class creation and syntax
  • Knowledge of standard C++ libraries, particularly std::ostream
  • Ability to interpret compiler error messages and build logs
  • Review the build log for detailed error messages in Microsoft Visual C++ 2005
  • Learn about function argument matching in C++
  • Explore common C++ compilation errors and their resolutions
  • Practice writing and debugging C++ classes in Microsoft Visual C++ 2005
C++ developers, students learning object-oriented programming, and anyone troubleshooting compilation errors in Microsoft Visual C++ 2005.
splac6996
I am using C++ 2005 and trying to create a new class I believe I wrote my program correctly but when I gry to build I get an error back
here is my debug report
1> _Elem=char,
1> _Traits=std::char_traits<char>
1> ]
1> while trying to match the argument list '(std::ostream, void)'
1>Build log was saved at "file://c:\Documents and Settings\DEWAND JONES\My Documents\CSCI 1020\HOMEWORK5.2\HOMEWORK5.2\Debug\BuildLog.htm"
1>HOMEWORK5.2 - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
can some tell me what that error means?
Technology news on Phys.org
GCC is cool. Do you use linux at school?
Check
It might have more usefull information about your error.
There's no such thing as "C++ 2005". You're using the program "Microsoft Visual C++ 2005", which is an IDE and compiler for the C++ programming language.
Usually, people post their code but not their error message, in this case it's the opposite. Posting your code would help. (And the complete error message. You've missed out the very lines where it tell you what problem it have with the code.)
  • · Replies 75 ·
  • · Replies 16 ·
