Solve the initial value problem
The discussion revolves around solving the initial value problem defined by the differential equation \(\frac{dx}{dt} = tx^{2} + 2x^{2}t^{2}\) with the condition \(x(2) = 0\). The user successfully factored out \(x^{2}\) and separated variables, leading to the integral \(\int \frac{dx}{x^{2}} = \int (t + 2t^{2}) dt\). The confusion arises when determining the constant \(C\), particularly due to the division by zero when substituting the initial condition. The solution \(x(t) = 0\) for all \(t\) is also recognized as valid.
  • Understanding of first-order differential equations
  • Knowledge of separation of variables technique
  • Familiarity with integration of polynomial functions
  • Concept of initial value problems in differential equations
  • Study the method of integrating factors for solving differential equations
  • Learn about the uniqueness and existence theorems for initial value problems
  • Explore the implications of trivial solutions in differential equations
  • Practice solving more complex initial value problems using different techniques
Students studying differential equations, mathematics educators, and anyone preparing for exams involving initial value problems in calculus or differential equations.
dashkin111
Solve the initial value problem given x(2)=0
[tex]\frac{dx}{dt}=tx^{2}+2x^{2}t^{2}[/tex]
I factored out the x^2 and separated variables and integrated as follows:
[tex]\int\frac{dx}{x^{2}} = \int t+2t^{2} dt[/tex]
[tex]\frac{-1}{x}=\frac{1}{2}t^{2}+\frac{2}{3}t^{3} + C[/tex]
Which is simple enough, but I get really confused when solving for C. Trying to solve from the equation above divides by zero and the world ends- rearranging explicitly for x doesn't do me any good either. Suggestions on where to go from here?
This may seem like kind of a cheat, but x(t)=0 for all t is also a solution.
Thanks for that, I didn't think of that case. If something similar shows up on the exam I'll always check for something like that
  • · Replies 105 ·
13K
  • · Replies 22 ·
