Relationship between light wavelength, intensity and photons energy
The discussion revolves around the relationship between light wavelength, intensity, and photon energy, particularly in the context of photovoltaic cells. The original poster seeks clarification on several concepts related to these topics.
  • The original poster poses questions regarding the correlation between wavelength, intensity, and energy of photons, specifically asking if shorter wavelengths correspond to higher energy and if higher intensity implies more photons. They also inquire about the implications for voltage and current generation in photovoltaic cells.
Some participants confirm the original poster's understanding of the relationship between wavelength and photon energy, as well as the connection between intensity and the number of photons. However, there is a counterpoint raised regarding the assumptions about voltage and current generation in photovoltaic cells, indicating that the relationship is not straightforward.
Participants are exploring the nuances of how different wavelengths of light interact with photovoltaic cells, noting that the conversion of photons to electrons may not directly correlate with the energy of the photons involved.
techguy
Hi peeps,
i am having a project and i wish to clear some concept.
1. The shorter the wave length the higher the photon energy? Am i right?
2. The higher the intensity of light, the higher amount of photons exist in the light? Am i right?
3. So higher intensity plus short wave length will give a lot of overall energy in the light? Am i right?
Thanks!
techguy said:
Hi peeps,
Correct
Spot on again
Yup.
Ok thanks! So here goes another question since my basic concept is correct...
so does that means that higher intensity plus short wavelength light, it will generate much more voltage and current as compared to same amount of intensity plus high wavelength light in photovoltaic cell?
No this is not neccessarily true.
This is mostly down to a couple of reasons...
1. The general rule is one photon will be converted to one electron and the energy of this photon is not related to the energy the electron will deliver in terms of current and voltage (the exception to this case being down conversion solar cells where a high energy electron may be converted into two low energy electrons).
2. The solar cell will respond differently to different wavelengths of light. Higher energy photon does not neccessarily mean more likely to be converted into a photon.
  • · Replies 35 ·
  • · Replies 35 ·
