Does the series \sum_{n=1}^\infty sin(\frac{1}{n^2}) converge?
  • Thread starter Thread starter NDakota
    Convergence Sum
The series \(\sum_{n=1}^\infty \sin\left(\frac{1}{n^2}\right)\) converges. This conclusion is reached by applying the comparison test, specifically comparing it to the convergent series \(\sum_{n=1}^\infty \frac{1}{n^2}\). Since \(|\sin(x)| \leq x\) for \(x \geq 0\), it follows that \(\sin\left(\frac{1}{n^2}\right) \leq \frac{1}{n^2}\). Thus, the series converges due to the properties of nonnegative terms in convergence tests.
  • Understanding of series convergence tests, particularly the comparison test.
  • Familiarity with the properties of the sine function, specifically \(|\sin(x)| \leq x\).
  • Knowledge of the p-series test, particularly the convergence of \(\sum_{n=1}^\infty \frac{1}{n^2}\).
  • Basic calculus concepts, including limits and inequalities.
  • Study the comparison test in detail, including its applications and limitations.
  • Learn about the limit comparison test and how it can be applied to series.
  • Explore the convergence of other trigonometric series for broader understanding.
  • Investigate the behavior of \(\sin(x)\) for small values of \(x\) to understand its implications in series.
Students studying calculus, particularly those focusing on series and convergence tests, as well as educators looking for examples of series convergence using trigonometric functions.
NDakota
Does the follow serie converge:
[tex]\sum_{n=1}^\infty sin(\frac{1}{n^2})[/tex]
For serie [tex]a_n[/tex] and [tex]b_n[/tex] if:
A = [tex]0 \leq a_n \leq b_n[/tex]
if [tex]b_n[/tex] converges then [tex]a_n[/tex] converges
I think that I have to use the equation (see 2) and then with
B = [tex]\sum_{n=1}^\infty \frac{1}{n^2}[/tex]
I think that it is larger than A. However I need proof... Any suggestions.
Thanks in advance.
For x>=0, |sin(x)| <= x. (Better yet, on [0,1], 0 <= sin(x) <= x.) Or you can just use the limit comparison test.
Note that both convergence tests require your series to have nonnegative terms.
