Angle viewed form erath between sun and planet.
  • Context: Undergrad
  • Thread starter Thread starter hulkster1988
    Angle Form Planet Sun
The discussion focuses on calculating the largest possible angle as viewed from Earth between the Sun and a hypothetical planet orbiting at 0.65 AU. It is established that the maximum angle cannot reach 180 degrees due to the Sun obstructing the view. The angle can be calculated using the arcsine function, specifically arcsin(0.65), and visualized by placing the Sun, Earth, and the planet in a triangular formation. The reference angle for Venus, approximately 45 degrees, serves as a comparative benchmark for understanding this geometric relationship.
  • Understanding of circular orbits in celestial mechanics
  • Familiarity with the concept of angles in geometry
  • Knowledge of the arcsine function in trigonometry
  • Basic comprehension of astronomical units (AU)
  • Research the calculation of angles in celestial mechanics using trigonometric functions
  • Explore the concept of coplanar orbits and their implications in astronomy
  • Study the geometric representation of orbits and angles in space
  • Learn about the visibility of celestial bodies from Earth, including factors affecting observation
Astronomy enthusiasts, students studying celestial mechanics, and anyone interested in understanding the geometric relationships between celestial bodies in our solar system.
hulkster1988
I'm having a hard time picturing this in my mind:
Calculate the largest possible angle as viewed from Earth between
the Sun and a hypothetical planet orbiting the Sun in a circular orbit with
a=0.65 AU. Assume Earth's orbit is circular and that Earth and the
hypothetical planet orbit the Sun in the same plane (coplanar orbits).
I assume the answer can't be 180 degrees as the sun would be blocking the viwer on Earth from seeing the hyporthetical planet. So I'm stuck on trying to viualize the cutoff at hwich point a viewer from the earht would be able to see the hypothetical planet?
Thanks for any help.
Marc
Astronomy news on Phys.org
You should take Venus as a reference. The highest angle possible of Venus seen from the Earth is about 45 degrees. Think about that.
Place the three bodies (sun, earth, planet) in a tight triangle with the planet at the right angle point. Net result is angle=arcsin(.65).
The best was to view it is to draw a circle representing the orbit of the planet around the sun. Place the Earth at some point ouside the circle, then draw a tangent from the Earth to the circle. The angle between the tangent and the earth-sun line is obviously the largest angle.
  • · Replies 86 ·
9K
  • · Replies 18 ·
