Help with Tension Homework: Calculate Net Upward Force & Tension
  • Thread starter Thread starter saber1357
    Tension
The discussion revolves around a physics problem involving a helicopter lifting a truck, focusing on calculating the net upward force and the tension in the cable. The subject area includes dynamics and forces, particularly the effects of gravity and acceleration on the system.
  • Participants explore the relationship between net forces, gravity, tension, and upward acceleration. Questions arise about how to account for different forces acting on the helicopter and whether the upward acceleration can be treated as a force.
Participants are actively engaging with the problem, questioning assumptions about forces and their interactions. Some guidance has been offered regarding the need to analyze forces separately for the helicopter and truck, and the distinction between forces and acceleration is being clarified.
There is an ongoing discussion about the necessity of analyzing the forces acting on both the helicopter and the truck, as well as the implications of treating them as a single object. Participants are considering the effects of gravity and the role of air resistance in the context of the problem.
saber1357
A 15,000 kg helicopter lifts a 4500 kg truck with an upward acceleration of 1.4 m/s2. Calculate (a) the net upward force on the helicopter blades from the air and (b) the tension in the cable between helicopter and truck.
F=ma
F = (m1+m2)a
I do not know how to even begin. Calculating the net upward force, I understand that an upward acceleration is given and that can be simply plugged into F=ma, however, what about gravity?
In F=ma, F stands for the net force. What forces act on the helicopter? I count three.
Aha! So you can simply add the force of gravity, upward acceleration, and tension together?
The "upward acceleration" is not a force, but is the result of all those forces acting. You mentioned gravity and tension--what's the third force on the helicopter? (Yes you can add up all the forces.)
Ah woah, if the upward acceleration doesn't produce the third force, then what does?
The air! (Acceleration is not a force!) As a result of those three forces, there's a net force which produces an upward acceleration. Obviously, the upward force of the air must be larger than the sum of the two downward forces.
You might also want to analyze the forces on the truck.
But isn't a force created due to the upward acceleration..? F=ma, with "a" being this upward acceleration?
Do the forces have to be analyzed separately for the truck? I thought I could just add the mass of the truck to the helicopter.
The fact that there's an upward acceleration allows you to deduce that there's a net upward force on the helicopter. That net force is due to the actual forces acting on the system. (Real forces have agents: things that exert the force.)
You are welcome to treat the helicopter + truck as a single combined "object", but that will not allow you to figure out the tension. But you can use it to find the force due to the air. (Realize that the rope tension acts on both helicopter and truck, so if you treat them as a single object, the tension cancels out.)
Gotcha! I really appreciate all the help you provided.
You are the thx.
<3
(If you ever need help finding someone to ask you loads of physics questions, I'm your man)
  • · Replies 18 ·
11K
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 25 ·
