Railroad Car: Man's Weight Affects Velocity Change
The discussion focuses on the relationship between the weight of a man standing on a moving railroad car and the resulting change in the car's velocity. Using the conservation of momentum, the formula change in v = w(v1 + Vrel)/W is established, where W is the weight of the car, w is the weight of the man, V1 is the initial speed of the car, and Vrel is the man's speed relative to the car. This indicates that the change in velocity of the car is directly proportional to both the man's weight and his relative speed as he moves off the car. Thus, a heavier man or a faster movement off the car results in a greater change in the car's velocity.
  • Understanding of conservation of momentum
  • Basic knowledge of physics concepts related to motion
  • Familiarity with the equations of motion
  • Ability to manipulate algebraic formulas
  • Study the principles of conservation of momentum in closed systems
  • Explore the effects of mass and velocity on motion using Newton's laws
  • Learn about frictionless motion and its implications in physics
  • Investigate real-world applications of momentum conservation in transportation systems
Physics students, educators, and anyone interested in understanding the dynamics of motion and momentum in mechanical systems.
skiboka33
?? railroad car
doesnt make sense... here goes...
A railroad car of weight W can roll without friction along a straight horizontal track. A man od weight w is standing on the acr which is moving at a speed of V1. Prove that change in v = w(v1 + Vrel)/W if Vrel is the speed of the man moving off the left end relative to the car. (car is going right, man is going left) thanks!
Conservation of momentum
Use conservation of momentum.
This statement is discussing the relationship between the weight of a man standing on a railroad car and the resulting change in velocity of the car. It is stated that the car is initially moving at a speed of V1, and the man is standing on the car and moving off the left end with a relative speed of Vrel. The formula provided in the statement, change in v = w(v1 + Vrel)/W, suggests that the change in velocity of the car is directly proportional to the weight of the man and the relative speed between the man and the car. This means that the heavier the man is, and the faster he is moving off the left end, the greater the change in velocity of the car will be. This is because the man's weight and movement will create a force on the car, causing it to accelerate or decelerate. Therefore, the weight of the man does have an impact on the velocity change of the railroad car.
12K
