What is the acceleration of each mass with a friction coefficient of .25?
The discussion revolves around calculating the acceleration of two masses, one weighing 7 kg and the other 12 kg, with a coefficient of friction of 0.25 affecting the 7 kg mass on an inclined plane. Participants are analyzing forces acting on the masses and the implications of friction in their calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to calculate net forces and accelerations, questioning specific values such as the frictional force and its derivation. There is a focus on understanding the components of forces acting on the masses and how they interact.
Several participants are engaged in clarifying calculations and assumptions, particularly regarding the net force and frictional force. There is a mix of agreement on certain values, but no explicit consensus on the overall approach or final acceleration values.
Participants are navigating through the complexities of force diagrams and the effects of friction, with some expressing uncertainty about specific calculations and the setup of the problem.
willingtolearn
Find the acceleration experienced by each of the two masses shown in the picture below if the coefficient of friction between the 7 kg mass and the plane is .25 ?
In the picture, is the force of fiction go that way ?
http://img515.imageshack.us/img515/893/img3394dj7.jpg
m1 = 7kg u = .25
m2 = 12kg
F (per) = F (normal)
F (per) = 68.6 cos 37 = 54.8 N
F (parallel) = 68.66 sin 37 = 41.3 N
F net = (12*9.8) - 1.75 = 115.85 N
115.85 / 19 = 6.1 m/s2
So 7 kg is accelerate at 6.1 m/s2 and 12 kg is the same but in the negative direction.
Is this right ?
can you explain this part:
"F net = (12*9.8) - 1.75 = 115.85 N"
how are you getting 1.75... and which mass are you taking Fnet for...
in this problem, there are only 2 force make the block able to slid. (and it is force of gravity on 12 kg and force friction on 7 kg.
So F net = F (gravity) - F (fiction)
but how do you get 1.75N?
Also what about the F (parallel) = 68.66 sin 37 = 41.3 N?
F (friction) = .25 time 7 = 1.75
But friction = 0.25*Fnormal = 0.25*7*9.8*cos37.
Although it might be faster to do the whole problem at once... I think it's best to divide into 2 sections...
do the freebody diagram of the first mass, get the equations there... then the second mass, get the equations there... use T for tension...
ok, I got this
a = 3.3 m/s2
ok, I got this
a = 3.3 m/s2
looks good to me. that's what I get also.
Yes ... thanks learningphysics
9K
9K
  • · Replies 19 ·
