Solving Diff Eq Tired Spring Problem: Find Min k for y(x) Cross y=0
  • Thread starter Thread starter andre_4
    Diff eq Spring
The discussion focuses on determining the minimum positive value of the constant k in the differential equation x²y'' + Ky = 0, with boundary conditions y(1) = 0 and y'(1) = 1. Participants suggest using a change of variable t = ln(x) to transform the equation into one with constant coefficients. The trial solution y = x^m is recommended to derive the characteristic equation, which may yield complex solutions. The conversation emphasizes the importance of correctly applying the chain rule to facilitate the transformation and analyze the solutions effectively.
  • Understanding of differential equations, specifically Euler type equations.
  • Proficiency in applying the chain rule in calculus.
  • Familiarity with characteristic equations and their solutions.
  • Knowledge of complex numbers and their application in differential equations.
  • Study the method of solving Euler type differential equations.
  • Learn about the transformation techniques for differential equations, particularly using logarithmic substitutions.
  • Explore the concept of characteristic equations in depth.
  • Investigate the handling of complex solutions in differential equations.
Students and educators in mathematics, particularly those studying differential equations, as well as engineers and physicists dealing with dynamic systems and oscillatory behavior.
andre_4
Determine the minimum positive value of the constant k needed to ensure that the function y(x) obeying
x^2 y'' + K y = 0, y(1) = 0, y'(1)=1
will not simply keep on increasing toward large x but will instead return to cross y=o ocassionally
So far I've tried doing a change of variable and trnasform t= ln(X). The idea is that I should get a constant coefficient equation but do not know how to get there yet.
I have tried using the chain rule twice to get from d^2y/dx^2 to d^2y/dt^2 but as said I do not seem to make any progress. Any ideas please?
Use the trial solution [tex]y=x^m[/tex]
That's an "Euler type" equation. As rock.freak667 said, you can reduce to the "characteristic equation" by trying y= xm. However, I suspect that equation will have complex solutions and it's not clear how to reduce that to real solutions to the d.e.
Yes, you can always reduce an "Euler type" equation to a constant coefficients equation by the substitution t= ln(x). You use the chain rule to change:
[tex]\frac{dy}{dx}= \frac{dy}{dt}\frac{dt}{dx}= \frac{1}{t}\frac{dy}{dt}[/tex]
[tex]\frac{d^2y}{dx^2}= \frac{d }{dx}\left(\frac{1}{t}\frac{dy}{dt}\right)[/tex]
[tex]= \frac{1}{t}\frac{d }{dt}\left(\frac{1}{t}\frac{dy}{dt}\right)[/tex]
In fact, the characteristic equation for the constant coefficients equation you get this way is exactly the same as the equation you get by trying y= xm but now you know that t= ln(x) so you can see what to do with complex solutions- exactly what you would do for a constant coefficients equation and then replace t by ln(x).
