Calculating the Height of a Cliff Using Projectile Motion
The discussion revolves around calculating the height of a cliff using projectile motion principles. The original poster presents a scenario where a ball is thrown towards a cliff at a specific speed and angle, and the time of flight is given.
  • Participants explore various equations related to projectile motion, including the vertical motion equation and the components of initial velocity. There is discussion on how to calculate the height of the cliff and the maximum height of the ball, with some participants questioning the assumptions made regarding time and vertical speed.
Participants are actively engaging with the problem, providing different approaches and corrections to each other's reasoning. Some have offered guidance on using the correct equations and understanding the components of motion, while others are questioning the validity of their calculations and assumptions.
There are indications of confusion regarding the initial conditions and the application of projectile motion equations, particularly in relation to the time of flight and the vertical component of velocity. Participants are also navigating the implications of the ball landing on a cliff rather than returning to the original height.
klm
A ball is thrown toward a cliff of height h with a speed of 30m/s and an angle of 60 degrees above horizontal. It lands on the edge of the cliff 4.0s later.
How high is the cliff?
do you just use the equation h=.5gt^2 ? and put it in -9.80=g and 4=t ?
You also need to consider the initial speed in the y-direction; here's the complete equation:
[tex]y = y_0 + v_{0y} t - (1/2) g t^2[/tex]
would this be correct: y0=26 , v0=30, g=-9.8 , t=4 ... so y=26+(30x4)- .5(-9.8)(4)^2 = 224.4 m ?
i got vy by doing v0sintheta= 26
No. In the formula I gave:
y0 is your initial position, which I presume is on the ground at height = 0
v0 (which I'll change to v0y) is the vertical component of the initial velocity, what you call v0sin(theta)
g = 9.8 m/s^2
To make it less confusing, I'll relabel v0 to be v0y in my equation.
ohh sorry, so y=0 + 26(4) - .5(9.8)(4)^2 = 25.6 m
Good!
thanks! can you help me with the next part too..! What was the maximum height of the ball?
i think the equation is just the same as the one you wrote, but just cut t=4 in half to get the peak height so t=2 ..so y= 26(2)-.5(9.8)(2)^2 = 32.4 m ?
No, you can't assume that the peak is at half the time. After all, it lands up on a cliff, so it spent more time rising than falling. (If it fell back down to the original height, then you'd be correct.)
Instead, use a velocity equation for the y-direction to figure out the time when it reaches maximum height. Hint: At the maximum height, what's the vertical speed?
um i think the vertical speed should be 0
so would it be okay to use the equation vfy= viy +ayT so 0= 26+9.8t so t= 2.65 and then cut then stick that time in that first equation you gave me?
so y= 26(2.65) -.5(9.8)(2.65)^2 =34 .4m ?
are the equations i used alright?
Very good!
thank you Doc Al! do you mind one more question, it will be the last one i promise! =)
What is the ball's impact speed?
i thought what you should do is find the final velocity in the x component and y component. and i thought that vfx= 15 since there is no acc in the x direction and vfy= -26 b/c of neg acc. and then i thought you should take the magnitude, but this does not work out to be right. do you know what i am doing wrong
wait i think i did this wrong, look at my next post please
oh no actually should vfy= 65.2 because i tried the equation vfy=viy+ay x T so 26+(9.8x4)= 65.2
so do i do square root (15^2 + 65.2^2) = 66.9 ?
Careful here. ay = -9.8 m/s^2.
ohhh so should it be vfy= -13.2 and then do the sqaure root (13.2^2 +15^2 ) =19.98
Good!
thank you so much doc al!
