Biot-Savart + Coulomb + Charge Conservation = Maxwell?
The discussion centers on the relationship between the Biot-Savart Law, Coulomb's Law, the Law of Charge Conservation, and Maxwell's Equations. Participants explore whether these three laws can be used to derive Maxwell's Equations, examining the implications of charge conservation and the conditions under which these laws apply. The scope includes theoretical considerations and mathematical reasoning.
  • Some participants suggest that Coulomb's Law and the Biot-Savart Law can be derived from Maxwell's Equations, while the same may not hold for the Law of Charge Conservation.
  • One participant proposes that the original question should focus on whether one set of equations can derive the other, highlighting the need for self-consistency among the equations.
  • Another participant argues that the three laws do not account for the radiation of electromagnetic waves, which may limit their ability to derive Maxwell's Equations fully.
  • Some participants discuss the role of charge conservation in the context of moving charges and the effects on electric and magnetic fields, questioning whether it is a fundamental component or a consequence of other laws.
  • There is a suggestion that requiring self-consistency might lead to the introduction of Faraday's Law, although the argument for this is not fully articulated.
  • One participant notes that Coulomb's Law is not universally valid, particularly in scenarios involving radiation, which complicates the derivation of Maxwell's Equations from the three laws.
Participants express differing views on whether the three laws can derive Maxwell's Equations, with no consensus reached. Some believe it is possible under certain conditions, while others argue against it due to limitations in the laws themselves.
Limitations include the potential for missing assumptions regarding the applicability of the laws in various scenarios, particularly concerning radiation and dynamic fields. The discussion also reflects uncertainty about the derivation process and the interdependencies of the laws involved.
Swapnil
Biot-Savart + Coulomb + Charge Conservation = Maxwell??
Do the Biot-Savart Law, Coulomb's Law, and the Law of Charge Conservation contain the same information as Maxwell's Equations? i.e.
[tex] \begin{cases}<br /> d\vec{B} = \frac{\mu_o}{4\pi} \frac{I d\vec{l} \times \hat r }{r^2} \\<br /> \vec{E}= \frac{1}{4\pi\varepsilon_o} \frac{Q \hat r}{r^2} \\<br /> \nabla \cdot \vec{J} = -\frac{\partial \rho}{\partial t} ,<br /> \end{cases}<br /> \overset{?}{=} <br /> \begin{cases}<br /> \nabla \cdot \vec{E} = \frac{\rho}{\epsilon_0} \\<br /> \nabla \cdot \vec{B} = 0 \\<br /> \nabla \times \vec{E} = -\frac{\partial \vec{B}}{\partial t} \\<br /> \nabla \times \vec{B} = \mu_0 \vec{J} + \mu_0 \epsilon_0 \frac{\partial \vec{E}}{\partial t},<br /> \end{cases}[/tex]
The original question I think is better phrased as, "can we use one set of equations to derive the other?". Coulomb's law and the Biot-Savart Law can certainly be derived from Maxwell's equations, I don't think the same is true for the Law of charge conservation however, because from memory, one needed to use this law to derive the amended version of Ampere's Law (I'm going on memory though so I could be wrong).
Claude.
Claude.
Yes. It can:
[tex]\nabla \times \vec{B} = \mu_0 \vec{J} + \mu_0 \epsilon_0 \frac{\partial \vec{E}}{\partial t}[/tex]
Take the divergence of each side:
[tex]\nabla \cdot \nabla \times \vec{B} = \mu_0 \nabla \cdot \vec{J} + \mu_0 \epsilon_0 \frac{\partial \nabla \cdot \vec{E}}{\partial t}[/tex]
Now, [tex]\nabla \cdot \nabla \times \vec{B} = 0[/tex] identially, while [tex]\nabla \cdot \vec{E} = \frac{\rho}{\epsilon_0}[/tex].
Thus, [tex]0 = \mu_0 \nabla \cdot \vec{J} + \mu_0 \epsilon_0 \frac{\partial \rho /\epsilon_0}{\partial t}[/tex]
Or, more simply [tex]\nabla \cdot \vec{J} = -\frac{\partial \rho}{\partial t}[/tex]
Claude.
I know that Maxwell's Equation can be used to derive all sorts of laws (which is why they are so famous and revered). I was actually interested in knowing if we can derive full-blown Maxwell's Equations (all 4 of 'em) using the set of three laws: {Coulomb's law, Biot-Savart Law, Law of Conservation of Charge}. Is that possible??
I don't think so, because these three laws do not contain the possibility of radiation of electromagnetic waves. If the radiation is neglected, and there are only charges and current elements interacting with each other, then, I believe, your assumption is correct.
Eugene.
Claude Bile said:
The original question I think is better phrased as, "can we use one set of equations to derive the other?". Coulomb's law and the Biot-Savart Law can certainly be derived from Maxwell's equations, I don't think the same is true for the Law of charge conservation however, because from memory, one needed to use this law to derive the amended version of Ampere's Law ...
it seems to me that since magnetic fields can only be generated by the movement of charges and since when charges move from one place to another, the place they move from experiences a net loss of charge (reducing, in time, the electrostatic flux emitted from that place) and the place they move to experiences a net increase of charge (increasing, in time, the electrostatic flux emitted from there), that the conservation of charge does have a role here. but i am trying to decide if it's a native ingredient or a consequence. i think the OP might have an insight of value here.
think of a nice cylinderical capacitor with two parallel circular plates and the two leads connected outward from the plates at right angles to the plane of the plates. the B field generated around the wires going in (where there is movement of charge) is the same as the B field generated around the empty space between the plates (where there is a changing electric field because of the accumulation of charge on the plates but no moving charge).
I'm not 100% certain about this; but, I'm thinking that, once you impose self-consistency, you might just be able to do this. Coulomb's Law and the Biot-Savart law are solutions of electrostatics and magnetostatics respectively. So, these should, alone, give rise to Gauss' Law and Ampere's Law. Again, playing the game with the divergence of Ampere's Law, and requiring charge conservation (a.k.a. continuity) will force the introduction of the displacement current term. So, these three conditions certainly allow the construction of everything other than Faraday's Law of Induction.
My feeling here is that requiring self-consistency among the equations probably, then, leads to the requirement that Faraday's Law hold; but, I haven't quite found the argument for it yet. I know that there's a relatively simple argument for the displacement current when the rest of Maxwell's equations are already in place; so, I would think that something might parallel that.
The way the original equations are written down, I think it won't be possible, because Coulomb's law, for instance, is not valid in all generality (when there is radiation for instance, you can have an E-field in the radiation which is NOT given by Coulomb's law).
