Gauss's Law/Energy Problem with Concentric Spheres
  • Thread starter Thread starter asiangrrl
    Spheres
The problem involves concentric spherical shells of radii a and b, carrying charges Q and -Q, respectively. The objective is to find the energy stored in the electric field of this system, as outlined in a textbook on Electricity and Magnetism.
  • The original poster attempts to apply Gauss's Law to determine the electric field in different regions and integrate to find the energy. Some participants question the setup of the electric field and the integration limits, while others clarify the nature of the charges and their impact on the electric field.
Participants are actively discussing the electric field expressions and integration methods. There is a mix of confirmations and clarifications regarding the calculations and assumptions made about the charges and their distributions. No explicit consensus has been reached, but several productive directions have been explored.
The discussion includes references to the use of cgs units instead of SI units, which may affect the constants involved in the equations. There is also an acknowledgment of potential confusion regarding the signs of the electric field due to the presence of both positive and negative charges.
asiangrrl
Hi there. I'm new to PF, so please correct me on any mistakes in presenting my question. I'm just hoping to get some direction in doing this problem right.
Concentric spherical shells of radius a and b, with b > a, carry charge Q and -Q, repsectively, each charge uniformly distributed. Find the energy stored in the electric field of this system.
(From Purcell, Electricity and Magnetism, 2nd Ed. [I hate this book ])
From Gauss's Law (for a sphere)
E= [tex]Q/r^2[/tex]
U = [tex]\frac{1}{8\pi} \int_{Entire field} E^2 dv[/tex]
I know I just have to sum up the E field and integrate over the volume of the entire sphere (or rather wherever the field is non-zero?) and that the E field will end up being a constant (or am I completely wrong?)
E inside inner sphere = 0 (field is zero inside spherical shell of charge)
E outside inner sphere = [tex]Q/(a^2)[/tex]
E inside outer sphere = [tex]-Q/b^2 + Q/a^2[/tex] (This one is the one I'm really unsure on)
E outside outer sphere = 0 (total charge is [tex]Q+(-Q) = 0[/tex])
And then do I integrate the E field squared in spherical coordinates from a to b? (As I end up with it as a constant I feel like I'm doing something wrong.)
Any help is greatly appreciated (I'm awful at E&M).
edit: Forgot to mention this is all in cgs units, not mks/si.
I'm confused... there are 30 concentric spherical shells? or just 2? (one at a and one at b?)
for a sphere... the field is [tex]E = \frac{Q}{4\pi \epsilon_0 r^2}[/tex]
And energy is [tex]\frac{\epsilon_0}{2}\int E^2dv[/tex]
Ah sorry about that, 1.30 is just the problem number. Just 2 concentric spherical sehlls.
I "ignored" the constants because I (or rather this book) uses cgs units instead of MKS or SI units.
oh I see... sorry about that.
In your work you said "E inside outer sphere" and "E outside inner sphere"... they both the same right? The field would just be Q/r^2 between the two shells as far as I can see... just using gauss' law and the charge of the inner shell...
The field outside the outer sphere and inside the inner sphere are both 0 (both using gauss' law)...
So you'd integrate [tex]\frac{1}{8\pi} \int_{Entire field} E^2 dv[/tex]
from a to b... with E being Q/r^2
Thanks so much. Now I just have to remember how to integrate a sphere haha. Just to confirm, I think my integral will look like this? I need to retake vector calculus :blushing:
[tex]E=\frac{-Q}{r^2}, E^2=\frac{Q^2}{r^4}[/tex]
[tex]U = \frac{1}{8\pi}\int \frac{Q^2}{r^4}dV, dV=r^2sin\phi dr d\phi d\theta[/tex]
[tex]U = \frac{1}{8\pi}\int_{0}^{2\pi}\int_{0}^{\pi}\int_{a}^{b} \frac{Q^2}{r^2} sin\phi dr d\phi d\theta[/tex]
Looks right to me. you can integrate over dtheta and dphi... and your left with an integral over r.
You can also use dV = [tex]4\pi r^2 dr[/tex] which is The area of a spherical shell times dr... (same thing as what you have just a quicker method to look at it).
Why did you use -Q/r^2 instead of Q/r^2 (it doesn't make a difference, but just wondering... since the inner sphere is radius a with charge Q)?
Ohhh thank you for that. So [tex]U = \frac{1}{2} \int_{a}^{b} \frac{Q^2}{r^2}dr[/tex] I think.
Yes, I know it doesn't make a difference in the end, but if it did, it is over the negative charge between the two spheres, right? Since inner sphere has charge Q and between inner and outer sphere the charge is -Q.
Your expression for U looks good to me.
For the field being Q/r^2 instead of -Q/r^2
Well, when you use gauss' law to find the field between the two spheres... you use a gaussian surface (a sphere)...
Gauss' law says that [tex]\int E\cdot dA = 4 \pi Q_{enclosed}[/tex]
So what is the charge enclosed in a gaussian sphere between the two given spheres... it is the charge of the inner sphere...
So field is Q/r^2 (not -Q/r^2).
I might be making a mistake... let me know if this makes sense.
Hmmm okay, I think that makes sense. Thanks again for all your help!
  • · Replies 18 ·
