Find the Moments of Inertia question
The discussion revolves around calculating the moments of inertia for a system of four masses connected by rigid rods. The specific tasks include finding the center of mass and determining the moments of inertia about different axes related to the masses.
  • Mixed
  • Participants explore the calculation of the center of mass and the moments of inertia using the provided equation. There are attempts to clarify the contributions of different masses to the moments of inertia based on their positions relative to the axes.
Some participants have provided calculations and corrections regarding the distances used in the moment of inertia formulas. There is an ongoing exploration of how the positions of the masses affect the calculations, with some participants questioning assumptions about the contributions of individual masses.
Participants are discussing the implications of the axis of rotation on the moment of inertia calculations, emphasizing the need to consider all masses in the assembly rather than isolating individual contributions.
aligass2004
The four masses shown in the figure below are connected by massless, rigid rods.
http://i241.photobucket.com/albums/ff4/alg5045/p13-17.gif
a.) Find the coordinates of the center of mass if Ma=100g and Mb=Mc=Md=230g.
b.) Find the moment of inertia about an axis that passes through mass A and is perpendicular to the page.
c.) Find the moment of inertia about a diagonal axis that passes through masses B and D.
I = mA(rA^2) + mB(rB^2) + etc...
I solved part a by taking the x coordinates times the masses and then dividing by all of the masses. I did the same thing for the y coordinates. For both the x and the y coordinates I got .058m. For parts b and c I tried using the above equation, but it didn't work. I assumed for part b that it would be zero because mass a is at the origin, but that was wrong.
Only the contribution due to mass a would be zero. Show exactly what you did for b and c.
For part b I just assumed it would be zero because it's at the origin, but that was wrong. For part c I calculated I = (.230kg)(.07m)^2 + (.230kg)(.07m)^2. I got .07 m by using the pythagorean theorem since I knew the other two sides of the triangle to be .1m.
But only mass A is at the origin. What about the others?
But A and C have different masses. Also: Be a bit more precise in your calculation of the side length.
I don't understand what the other masses have to do with anything for one question about mass A and the other question about masses B and D.
You are misunderstanding the question. In both questions they are asking for the moment of inertia of the entire assembly of all four masses. The only difference is where the axis is, which changes the moment of inertia.
Oh, I see. Let me try to figure it out.
For part b, would it I = (.100)(0) + (.230)(.05^2) + (.230)(.07071^2) + (.230)(.05^2)?
Double check the distances from the axis.
The axis is at A. So B and D would remain the same distances, and C would be 14.142cm.
That's better.
For part b, I got .0092 kgm^2. For part c I recognized that B and D would be zero, so I = (.1)(.07071^2) + (.230)(.07072^2) = 1.65 x 10-3. Both were right. Thanks so much!
  • · Replies 21 ·
  • · Replies 40 ·
