Velocity of a particle large and small times
  • Thread starter Thread starter rock.freak667
    Particle Velocity
The problem involves the velocity of a particle moving along the x-axis, described by a differential equation relating velocity and time. The task is to express velocity in terms of time, given specific initial conditions, and to analyze the behavior of this velocity as time approaches both large and small values.
  • Participants discuss the application of a differential equation to find velocity and explore the implications of the initial conditions. There are attempts to analyze the behavior of the solution as time increases and to deduce the oscillatory nature of the velocity. Questions arise about the limits of trigonometric functions and their combinations.
The discussion is ongoing, with participants providing insights into the oscillatory behavior of the velocity function and its amplitude. Some participants suggest methods for combining trigonometric terms to determine the overall behavior of the velocity as time approaches infinity.
Participants note the importance of understanding the limits of the functions involved and the implications of the initial conditions on the solution. There is an emphasis on the oscillatory nature of the velocity and the need to consider maximum and minimum values in the analysis.
rock.freak667
The velocity,v, of a particle moving on the x-axis varies with the time,t,according to the differential equation [itex]\frac{dv}{dt}+2v=sint[/itex]. Find v in terms of t given that v=0 when t=0. Deduce that when t is large;the velocity of the particle varies between -0.45 and 0.45. Show that is t is very small,then [itex]v\approx\frac{1}{2}t^2[/itex]
[tex]\frac{d}{dx}(\frac{e^{2t}}{5}(2sint-cost))=e^{2t}sint[/tex]
[tex]\frac{dv}{dt}+2v=sint[/tex]
[tex]X e^{2t}[/tex]
[tex]e^{2t}\frac{dv}{dt}+2e^{2t}v=e^{2t}sint[/tex]
[tex]\int...dt[/tex]
[tex]ve^{2t}=\frac{e^{2t}}{5}(2sint-cost)+C[/tex]
using the initial values they gave me [itex]C=\frac{1}{5}[/itex]
And so
[tex]v=\frac{1}{5}(2sint-cost)+\frac{e^{-2t}}{5}[/tex]
As [itex]t\rightarrow\infty(large),\frac{e^{-2t}}{5}\rightarrow0[/itex]
but [itex]\frac{1}{5}(2sint-cost)[/itex] does not approach any limit as both cost and sint oscillate between 1 and -1.
[tex]X e^{2t}[/tex]
And so
no not between -1 and 1 that is for individual terms.You have to combine them into 1 cosine term and the new amplitude is ur answer.
use the below formula:
A sint + B cost = (A^2+B^2 ) ^(1/2) * Cos(t-arctan(b/A))
but wouldn't Cos(t-arctan(b/A)) not approach a limit? Or would t tending to infinity mean that t would eventually be equal toarctan(B/A) and so it would be the cos0=1?
the final limit will include a function that oscillates between some numbers.
since that function will oscillate it means that the velocity will vary.
Between [-0.45,0.45] in this case.
You will have to plug in the numbers that lead to the maximum value (0.45) and the minimum (-0.45). and that will be it for t->infinity.
Oh...thank you...shall try the next part now
yes it is just the amplitude as I said [( 2/5)^2 + (1/5)^2 ] ^1/2 = +-0.45
  • · Replies 17 ·
