Thread Closed
Pulley System Kinetic Energy
Share Thread Thread Tools
Oct14-07, 05:47 PM   #1
Force of gravity = 10
http://img80.imageshack.us/img80/1156/kineticec6.png
Pulley System
Two unequal weights, A = 6KG and B = 4KG
What is the kinetic energy of the movement after 4 seconds?
I think my calculations are so far correct... please point me in the right direction.
2. Relevant equations
KE = 1/2mv^2
3. The attempt at a solution
Acceleration of the two weights
a = g (A-B)
(A+B)
a = 10 (6-4)
(6+4)
a = 2ms
Force of gravity acting on weights
Weight 'A' (6KG)
F = MA
F = 6 * 10
Weight 'B' (4KG)
F = MA
F = 4 * 10
Ive also made an attempt to calculate velocity:
Velocity of masses
V = Sqr 2gh (6-4)
(6+4)
= (Sqr Rt)100
= 10
However I made another calculation and found the acceleration of the both weights to be 7.3, and by using SUVAT that the velocity is 29.3 with that figure of 7.3 for acceleration. To be honest im completely lost, please help.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Oct14-07, 06:04 PM   #2
Mentor
You found the acceleration. Assuming it starts from rest, what must be the speed after 4 seconds?
Sounds like you found the acceleration using two methods and got different answers. What was the second method that you used?
As far as the first method goes, did you derive that equation yourself or are you using a formula given in your text?
Oct14-07, 06:07 PM   #3
My tutor gave a homework question with that diagram, he said. Find the kinetic energy of the movement after a period of 4 seconds. Nothing was provided to us, the formulas I have used come from this website http://www.sparknotes.com/testprep/b...section2.rhtml . I read through it and tried to apply the given formulas.
Oct14-07, 06:12 PM   #4
Mentor
It's generally better to derive your own equations from basic principles (Newton's 2nd law). But the formula and answer for the acceleration that you gave is correct. Use kinematics to find the speed after 4 seconds.
Oct14-07, 06:23 PM   #5
S 25
U 0
V ?
A 2
T 4
V = U + A * T
V = 0 + 2 * 4
V = 8
So where do I go from here? I now know the Velocity, what about the masses.
Oct14-07, 06:25 PM   #6
Mentor
You have the velocity, now calculate the kinetic energy.
Oct14-07, 06:27 PM   #7
Kinetic Energy = 1/2 M V^2
1/2 10 * 8^2
= 320
Oct14-07, 06:30 PM   #8
So 320 is the final answer?
Oct14-07, 06:35 PM   #9
Mentor
Quote by sequenced_chaos View Post
Yes. Be sure to attach proper units to your answer.
Oct14-07, 06:36 PM   #10
Thanks very much for your time, much aprechiated :D
Thread Closed
Thread Tools
Similar Threads for: Pulley System Kinetic Energy
Thread Forum Replies
Kinetic Energy on Pulley/Incline System Introductory Physics Homework 9
Rotational Energy and Pulley System Introductory Physics Homework 5
Pulley System Introductory Physics Homework 4
Finding the masses of two blocks in a pulley system using work-energy theorem Introductory Physics Homework 3
