Angular motion with constant acceleration
The discussion revolves around two particles, A and B, both undergoing angular motion with constant acceleration. The problem involves determining the time after a specific moment when the angular velocity of particle B equals that of particle A, given their respective angular positions and velocities at that moment.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss writing expressions for the angular velocities of both particles as functions of time. There are attempts to equate these expressions to find the time difference after a specified moment.
Some participants express confusion about their calculations and seek clarification on the correct approach. There are indications of algebraic manipulation being necessary to equate the angular velocities. Multiple interpretations of the problem setup are being explored, with no clear consensus yet.
Participants note the importance of considering the time lag for particle B and the initial conditions for both particles. There is also mention of specific values for angular acceleration and velocity that need to be accounted for in the equations.
jaded18
Consider two particles A and B. The angular position of particle A, with constant angular acceleration, depends on time according to theta(t)=theta_0+omega_0t+alpha t^2. At time t=t_1, particle B, which also undergoes constant angular accelaration, has twice the angular acceleration, half the angular velocity, and the same angular position that particle A had at time t=0.
How long after the time t_1 does the angular velocity of B have to be to equal A's?
___
ok, here we go:
i know that i have to write expressions for the angular velocity of A and B as functions of time, and solve for t-t1?
For A, omega(t) = omega_0 + alpha(t) and
for B, omega(t) = 0.5 omega_0 + 2alpha(t-t_1)
so when i equate them and solve for t-t_1, i get something that is not the right answer!
please help :(
One wants expressions for [itex]\theta_A(t)[/itex] and [itex]\theta_B(t)[/itex], which are set equal at time t, so one can solve for time t, then find t - t1.
at t = 0, [itex]\theta_A(0)[/itex] = [itex]\theta_0[/itex], and at t=t1, [itex]\theta_B(t_1)[/itex] = [itex]\theta_0[/itex], which is the starting position of A at t=0.
In the expression for B, one has to address the time lag t1.
can anyone please just lay it out for me .. because i can't see it
One has for A, [tex]\theta(t)[/tex] = [tex]\theta_0\,+\,\omega_0t+\alpha t^2/2[/tex],
and for B, one must use t-t1 since it starts at t1, with
angular acceleration [itex]2\alpha[/itex] and angular velocity [itex]0.5\omega[/itex].
At the same position [tex]\theta_A(t)[/tex]=[tex]\theta_B(t)[/tex]
how do i get to the answer. i know that the answer is (omega_0 + 2alpha(t_1)) / (2alpha) but i want to know how they got that. and i need to know what i did wrong in #1 box because it looks okay to me
i KNOW theta A equation and theta B equation.
Oops, sorry, I was solving for the same position.
If theta(t)=theta_0+omega_0t+ 0.5alpha t^2 for A, then
omega_A(t) = omega_0 + alpha *t
for B
omega_B(t) = 0.5*omega_0 + 2 alpha *(t-t1)
when one differentiates t2, the derivative is 2t.
you are wrong. i am sorry. i will change what i said in #1
Consider two particles A and B. The angular position of particle A, with constant angular acceleration, depends on time according to theta(t)=theta_0+omega_0t+0.5alpha t^2. At time t=t_1, particle B, which also undergoes constant angular accelaration, has twice the angular acceleration, half the angular velocity, and the same angular position that particle A had at time t=0.
___
ok, here we go:
please help :(
IT IS 0.5 ALPHA T^2
THEREFORE For A, omega(t) = omega_0 + alpha(t) and
now what do i do with these equations?
I suspect the problem is simply algebraic.
Equate the two expressions for angular velocity.
[tex]\omega_A(t) = \omega_B(t)[/tex]
[tex]\omega_0\,+\,\alpha{t}\,=\,\omega_0/2\,+\,2\alpha{(t-t_1)}[/tex]
which leads to
[tex]\omega_0/2 \,=\, 2\alpha{(t-t_1)}\,-\,\alpha{t}[/tex]
or
[tex]\omega_0/2 \,= \,\alpha{t} - 2 \alpha{t_1}[/tex]
take an alpha t_1 to the other side
[tex]\omega_0/2 + \alpha{t_1} \,= \,\alpha{t} - \alpha{t_1}[/tex]
and see where that leads one
  • · Replies 17 ·
  • · Replies 32 ·
