Repulsive Forces: Gravity, EM & Nuclear Forces
  • Context: Graduate
  • Thread starter Thread starter Claude Bile
    Forces
The discussion revolves around the nature of repulsive forces in physics, particularly focusing on gravitational, electromagnetic, and nuclear forces. Participants explore whether nuclear forces can exhibit repulsive behavior, the implications of the cosmological constant, and the nature of forces that prevent planets from falling into the Sun.
  • Some participants propose that nuclear forces can exhibit repulsive behavior, particularly in the context of the strong nuclear force, which is likened to electromagnetism with its own unique properties.
  • Others argue that the concept of gravitation being always attractive may overlook the possibility of a mysterious repulsive force that prevents planets from falling into the Sun.
  • A participant suggests that the cosmological constant may not be a force at all, but rather an energy density, raising questions about its classification.
  • There is a humorous exchange regarding the idea of "angels" as a whimsical explanation for planetary motion, highlighting the contentious nature of the discussion.
  • Some participants challenge the validity of certain claims, labeling them as "crackpot" theories, while others defend the need for constructive criticism and open-mindedness in discussions about quantum theory.
  • A later reply emphasizes that planets do not fall into the Sun due to their tangential velocity, which allows them to miss it consistently.
Participants express multiple competing views regarding the nature of forces involved in planetary motion and the classification of the cosmological constant. The discussion remains unresolved with no consensus on these topics.
Some arguments rely on specific interpretations of quantum mechanics and force interactions, which may not be universally accepted. The discussion includes speculative elements and varying levels of acceptance of unconventional ideas.
Claude Bile
Gravitation is always attractive,
Electromagnetism is sometimes attractive, sometimes repulsive.
Here's my questions:
Do the two nuclear forces exhibit any repulsive behaviour, in any shape, way or form, or are they always attractive like gravity?
What about the cosmological constant? Is it a repulsive form of another force, or a totally new force?
Short answer: yes
Long answer: It turns out 'particles' and 'forces' are a bad way to think about the nuclear forces (and the other ones at small scales.) A better way is to think about fields and interaction energy terms, or vertices and virtual particles.
However, if you insist upon it, the strong nuclear force is vaguely like electromagnetism, except with three 'charges', called colors: red, blue, and green. The strong force acts to enforce color-neutrality, just as the electromagnetic force acts to enforce charge-neutrality. So like colors repel, while unlike colors attract.
Yep, and two protons have an energy curve due to the strong force that looks quite a bit like an ionic bond curve - asymptotic at close distances, with a minimum, and horizontal asymptote at large distances.
Hi Claude,
Your stipulation that gravitation is always attractive overlooks the possibility that some mysterious repulsive force must exist to explain why the planets do not fall into the Sun. While your second stipulation is valid there is no way that electromagnetism can account for the mystery. Perhaps the nature of the mystery force might be better understood by an analogy of the force fields present in the stable two-electron QM orbital.
The property of repulsion of like charges follows from the monopolar electrostatic force but then nature has intrinsically and permanently coupled the unit charge to its unitary mass (emu) where it exists as another monopolar but attractive force [as you have stipulated]. But hold on: it has been known for decades that the ratio of these supposedly compensating forces is so overwhelmingly dominated by the electrostatic force that there must be another force that keeps the orbital from flying apart. The realization that spin is another intrinsic property of these orbital electrons leads to the dipolar aspect of monopolar charge that is called magnetism. Now if one imagines the two orbital electrons as having parallel spins, then the magnetic force would be repulsive; on the other hand, the freedom of electrons to flip led Pauli to his valid discovery that allows the attractive force that would compensate electrostatic repulsion. So far three forces have been identified and none of them accounts for the energy and non-radiative stability of the orbital. First off, if the magnetic force exactly compensated the electrostatic force, nothing much would happen suggesting that magnetic attraction exceeds electrostatic repulsion and therefore the mysterious missing force must be repulsive.
Considering the loop character of the orbital, it is easy to see that nature uses voltage to determine radius and current that satisfies Planck’s distinctly positioned orbital. Of course it was logical to dismiss monopolar mass but without some dipolar aspect of electronic mass there would be no torque to exactly counter the loop magnetic dipolar attribute of the loop electron current. Furthermore, without the angular momentum necessary to permanently fix the orbital, energy would have to be continuously maintained. Looking back at the intrinsic spin-property of the electron and remembering that along with the spinning charge that produced dipolar magnetism the spinning iota of mass is the mysterious dipolar force that is responsible for the centrifugal force required for the creation of matter.
Thanks for your audience. Cheers, Jim
Angels. There are angels, keeping them from falling into the Sun, and pushing them too -- something's got to be keeping them moving, right?
Wow... I actually wasn't aware that NEOclassic was a crackpot.
- Warren
Originally posted by NEOclassic
Hi Claude,
... Cheers, Jim
Planets actually do, and all the time. The Sun is simply too small (and planets are too far from it), so they just miss it all the time.
Will your bad day ever end?
- Warren
Warren you really are a negative entity in this forum. Instead of shooting off with such as "crackpot", really read the post and dish out a little constructive criticism or is your mind closed to Quantum theory expressed in other than QED's "standing wave" modeling of a Pauli two-electron quantum orbital.
Your post began with "some mysterious repulsive force must exist to explain why the planets do not fall into the Sun," crackpot. How much more does one need to read?
- Warren
LOL this thread has exquisite oneliners
nothing can top these
I guess Kepler would have preferred the angels explanation
and Newton would go along with them falling but always missing
so we have good authority on both sides
my own two-bits is that the original poster started
the thread asking, among other things, if the
cosmological constant is a force then is it a new force
or a repulsive force. I don't think it is a force at all
(tho it might be an energy density). Does anyone want
to reply to the original poster on that?
PS this is a great board and everybody is to be
congratulated, even the crackpots(as chroot calls them)
are good crackpots IMHO
Eh... Alexander wasn't joking. There is indeed in circular motion an unbalanced acceleration towards the centre of mass of the system. The planets just have enough of a tangential velocity to miss it every time.
Er...I realize that, which is why I said Newton would agree
with that picture.
Kepler, on the other hand, would have inclined towards
the agency of angels I suspect. Alexander's way of putting
it was however a witty comeback "they do fall into the sun
but it is so small they keep missing" and made me laugh.
sometimes the truth appears in a comic light.
  • · Replies 18 ·
