Complex Integration Homework: Compute Integrals w/ Principle Value of z^i
The discussion focuses on computing integrals of the form \(\int z^{i} dz\) along specified paths \(\gamma_{1}(t)=e^{it}\) for two intervals: \([- \frac{\pi}{2}, \frac{\pi}{2}]\) and \([\frac{\pi}{2}, \frac{3\pi}{2}]\). The user attempts to apply branch cuts along the negative and positive real axes, respectively, to ensure that \(z^{i}\) remains analytic along the chosen paths. The antiderivative \(F(z)=\frac{z^{i+1}}{i+1}\) is correctly identified, leading to the conclusion that both integrals yield the same result, \(cosh(\frac{\pi}{2}) + cosh(\frac{\pi}{2})i\). The user seeks clarification on whether parameterization is necessary for their approach.
  • Complex analysis fundamentals, including integrals of complex functions
  • Understanding of branch cuts in complex functions
  • Knowledge of analytic functions and their properties
  • Familiarity with the concept of antiderivatives in complex integration
  • Study the application of branch cuts in complex analysis
  • Learn about parameterization techniques for complex integrals
  • Explore the properties of entire functions in complex analysis
  • Investigate the implications of Cauchy's integral theorem on analytic functions
Students and professionals in mathematics, particularly those focusing on complex analysis, integrals, and analytic functions. This discussion is beneficial for anyone looking to deepen their understanding of complex integration techniques.
strangequark
Compute the following integrals using the principle value of [tex]z^{i}[/tex]
a.
[tex]\int z^{i} dz[/tex] where [tex]\gamma_{1}(t)=e^{it}[/tex] and [tex]\frac{-\pi}{2}\leq t \leq \frac{\pi}{2}[/tex]
b.
[tex]\int z^{i} dz[/tex] where [tex]\gamma_{1}(t)=e^{it}[/tex] and [tex]\frac{\pi}{2}\leq t \leq \frac{3\pi}{2}[/tex]
There is a "hint" with the problem that says one of the integrals is easier than the other.
I don't see why, for part a, I can't use a branch cut along the negative real axis, so that [tex]z^{i}[/tex] will be analytic along the path.
And for part b, i don't see why I can't simply use a different branch cut, say one along the positive real axis, so that [tex]z^{i}[/tex] will then be analytic along that path.
Then for each, I can just take the antiderivative:
[tex]F(z)=\frac{z^{i+1}}{i+1}[/tex]
and plug in the end points...
If I do, I get:
a. [tex]\int z^{i} dz = \frac{i^{i+1}}{i+1}+\frac{(-i)^{i+1}}{i+1} = (\frac{e^{\frac{\pi}{2}}}{2}+\frac{e^{\frac{\pi}{2}}}{2}i)-(-\frac{e^{\frac{\pi}{2}}}{2}-\frac{e^{\frac{\pi}{2}}}{2}i ) = cosh(\frac{\pi}{2})+cosh(\frac{\pi}{2})i[/tex]
and I will get the same thing for b.
Is there something I am missing? Do I ned to parameterize the integral or is what I am doing correct?
Thanks in advance!
I'm thinking that because [tex]f(z)=z^{i}[/tex] is entire, and that the region in which the curve lies will be simply connected... then the anitderiv exists and since [tex]i[/tex] is just a constant, then the primitive of [tex]f(z)[/tex] will be [tex]F(z)=\frac{z^{i+1}}{i+1}[/tex]...
does anyone have any ideas? I'm really stuck here... thanks
  • · Replies 105 ·
13K
