Is Every Infinite Set Countable? Understanding Finite vs. Infinite in Topology
  • Thread starter Thread starter rumjum
    Infinite Topology
The discussion revolves around the concepts of countable and uncountable sets in the context of set theory and topology. Participants explore the definitions and implications of these terms, particularly in relation to infinite sets and specific examples such as the interval [a,b].
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants question the relationship between finite and infinite sets, particularly whether all infinite sets are countable. They also seek clarification on why certain sets, like the interval [a,b], are considered uncountable.
  • There are discussions about the implications of a set being uncountable and whether its complement can be countable, with examples being requested to illustrate different scenarios.
The conversation is active, with multiple participants providing insights and examples. Some guidance has been offered regarding the definitions of countable and uncountable sets, as well as references to Cantor's diagonal argument. However, there is still a lack of consensus on certain points, and participants continue to seek clarification on their understanding.
Participants express confusion about the definitions and implications of countable versus uncountable sets, indicating a need for further exploration of these concepts. There are references to specific examples and arguments that may not be fully resolved within the discussion.
rumjum
I always get confused between countably many vs. uncountable. I suppose if one can index the points of a set , then it is countable.
1)So, anything that is finitie is countable. Anything that is infinite is also countable?
Then what is uncountable, something that is both uncountable and infinite.
2) It is mentioned that line [a,b] is uncountable. But, why?
3) Also if a set is uncountable then the complement of that set is countable? I don't think so because for all x that belong to R and do not belong to [a,b]. The set still belongs to R and should be uncountable.
Can someone explain these loose ends of my understanding?
Uncountable means that you can't count EVERY element in it. Uncountable immediately implies infinite, as every finite set is countable (count them!).
My new catchphrase: If only there was some global database available to the public to freely share information.
By count, ZioX means index with integers. There are sets you can't do this with. See 'Cantor diagonal arguments'. A set could be uncountable and have a countable complement. It also could not. Give examples of both, please??
No, for example, the set of all real numbers is uncountable.
Yes, but normally we don't bother to say "infinite" since all finite sets ARE countable. "Uncountable" itself implies "infinite".
As said before, Cantor's diagonal argument. You should have see that when you were first introduced to "countable" and "uncountable".
Certainly not! Why would you think so? Yes, the set of all real numbers between 0 and 2 is uncountable. The set of all real numbers between 0 and 1 is uncountable. It's complement in the set of all real numbers between 0 and 2 is the set of all real numbers between 1 and 2 which is still uncountable.
If that set is 1, 2, 3, 4, ... (or a subset of it) - then yes.
For example, the set of numbers {1, 2, 3} is clearly countable as I can count all the numbers in them. So is the set {1, 2, 3, 4, ...} (all natural numbers) - I can assign each number to itself. The set {2, 4, 6, 8, ...} of even numbers is countable, because I can assign to each number n the number 2n (that is, describe the set as [itex]a_n = 2n[/itex]). Also, the set of all integers is countable (just write them in the peculiar order {0, 1, -1, 2, -2, 3, -3, 4, -4, ... } and you see that you can list them, in principle).
The set of all real numbers between 0 and 1 is not countable. For any countable list you give me, I can always give you one that is not in the list (this is the Cantor diagonal argument mentioned). Also, the set of continuous functions on [0, 1] with f(0) = 0 is uncountable, for example, the set of functions
[tex]\{ f(x) = a x \mid a \in \mathbb{R} \}[/tex]
is uncountable (even if we restrict a to the interval [0, 1], it is basically the same as this interval since each choice for a will define such a function). But then the subset of all functions
[tex]\{ \sin 2 \pi n x \mid n \in \mathbb{N} \}[/tex]
is countable, as each number n fixes such a function.
  • · Replies 18 ·
