How do I balance this redox equation for my homework?
  • Thread starter Thread starter xpatelsxownage
    Redox
The discussion revolves around balancing a redox equation involving HIO3, FeI2, and HCl in an aqueous solution. Participants explore various methods to balance the equation and clarify the half-reactions involved.
  • Homework-related
  • One participant presents the initial redox equation and attempts to identify oxidation states for the reactants and products.
  • Another suggests that balancing should be done through half-reactions, emphasizing the need to identify substances being oxidized and reduced.
  • Some participants express confusion about how to balance the half-reactions, particularly regarding the role of iodine in the reactions.
  • A later reply proposes a specific method of balancing the equation using HCl, H+, and H2O, while another participant questions the appropriateness of adding HCl directly.
  • One participant provides a balanced equation as a potential solution but acknowledges the need for proper balancing techniques.
  • There is a discussion about whether adding HCl is standard practice in redox titrations, with differing opinions on its validity.
  • Participants reflect on their understanding of the problem and express gratitude for the assistance received.
Participants do not reach a consensus on the best method to balance the equation, with multiple competing views on the use of HCl and the approach to half-reactions remaining evident throughout the discussion.
Some participants note that balancing redox reactions typically involves adding electrons, H+, or H2O, but there is uncertainty about the specific application of these methods in this case. The discussion also highlights the complexity of balancing redox equations and the potential for different interpretations of the problem.
xpatelsxownage
For those who have mastered the balancing of any type o redox equation, an extra challenge is provided below. Balance each of the following equations. Note: all of the reactions take place in aqueous solution.
HIO3 + FeI2 + HCl ====> FeCl3 + ICl + HOH
The oxidation numbers that is got in order of equation
reactants
H +1
I +5
O3 -6 (-2each)
Fe + 2
I -2 (-1each)
H +1
Cl -1
Products
Fe +3
Cl3 -3 (-1each)
I +1
Cl -1
H +1
O -2
H +1
The two half reactions (I'm not sure about these, though this is only thing that comes to my head)
1. FeI2 ===> FeCl3 (I don't get how i would balance these) do i add HCl to the right side and ICl and HOH to the left?
2. HIO3 ===> ICl Do I add HCl to the right and HOH to the left?
i asked all my friends but none seem to know how to do these. i have more like this but if i know how to do this i would get the rest.
Do i balance it first? 5HIO3 + 4FeI2 + 25HCl ==> 4FeCl + 13 ICl + 15HOH
All help Appreciated Thanks!
Well first you want to balance the equation. Then you carrry out the two half reactions. Which is separated into the substance being reduced and the substance that's being oxidized. Think you can do it now? Also the only way you balance in half reactions is by adding electrons or H+ or H20
i don't get what the two half reactions would be like the fe loses an electron and the iodine gains an electron.
so i got the two half reactions a
FeI2 ==> FeCl3
HIO3 ===> ICl
i don't get how to balance these because in the first one where does the iodine go.
so far in class all we did was when there are two reactants and two products so I am stumped
What is the question specifically asking?
its asking to balance the redox equation
Well the only way i can see you doing it is this way FeI2 +HCl====> FeCl3 + H2O as one reaction and FeI2 ==> FeCl3. Balance using acid, bases, and electrons. If you get stuck just ask. You don't need to balance the equation into this 5HIO3 + 4FeI2 + 25HCl ==> 4FeCl + 13 ICl + 15HOH. The whole point is that redox will balance it.
Edit: I misread part of you problem. Guy below me did it right
KEY STEP: To determine the half reactions, look at the oxidation states and what is losing and what is gaining electrons
HIO3 (I = +5) --> ICl (I = +1) reduction
FeI2 (Fe=+2) (I = -1) ---> ICl (I = +1) + FeCl3 (Fe = +3) oxidation;
balance Cl by adding HCl, H+ for H and H2O for O
you will need to multiply both reactions to get the electrons to cancel out
but when they do, and you add the two half reactions and cancelling H+ where needed, you do get back the balanced equation
25HCl + 4FeI2 + 5HIO3 ---> 13 ICl + 15H2O + 4 FeCl3
that IS a good problem
Your not supposed to do it for him just help him get to it himself. And it's not a good problem because your not really allowed to add acids like hcl. You can acids as H+ and bases as OH-
what do you think H+ is in the form of? HCl can be put in the half reactions as well.
with the other half reactions suggested, not sure how the I would have been balanced
the key step is to look at the oxidation states, well, yes maybe I did give a little too much info..
nvm, I misread part of his problem. I didn't see the charge of I also changed
:smile:come on, you have to admit, it was GOOD problem
It wasn't as good as I thought at first. Now it's just a regular redox equation. Before I thought it was something I've never seen.
Edit: I wonder if he understood
i do understand it now. the problem was i didnt know you could add hcl. that helps a lot. thank you both for your help and effort.
Adding HCl to balance redox titration is not normal procedure but it works in this case because Cl- charge does not change, essentially a spectator ion, so its going to be there anyway in that form. Just some different thinking - I haven't done many of these. You did assign the oxidation states well, keep them in mind before and after.
