| Thread Closed |
[SOLVED] QM simple harmonic oscillator |
Share Thread | Thread Tools |
| Oct16-07, 07:25 PM | #1 |
If I have a particle in an SHO potential and an electric field, I can represent its potential as: [tex] V(x) = 0.5 * m \omega^2 (x - \frac{qE}{mw^2})^2 - \frac{1}{2m}(\frac{qE}{\omega})^2 [/tex] I know the solutions to the TISE: [tex] -\hbar^2 /2m \frac{d^2 \psi}{ dx^2} + 0.5 m\omege^2 x^2\psi(x) = E\psi(x) [/tex] (*) (Those are different Es) So, I plug V(x) into the TISE and get: [tex] -\hbar^2 /2m \frac{d^2 \psi}{ dx^2} + (0.5 * m \omega^2 (x - \frac{qE}{mw^2})^2 - \frac{1}{2m}(\frac{qE}{\omega})^2) \psi(x) = E\psi(x) [/tex] Now, since we only shift and translated the potential, I should be able to find a substitution for x that yields the equation (*) in a new variable y = f(x), right? The problem is, after I move the constant term to the RHS, I cannot find the right substitution. What am I doing wrong? 2. Relevant equations 3. The attempt at a solution |
| Oct16-07, 11:08 PM | #2 |
I think that I can even prove that there is no constant that you can add to x to find a suitable substitution. Something must be wrong here?
| Oct17-07, 12:07 AM | #3 |
Have you tried the obvious substitution: [itex]\xi = x-qE/m\omega ^2 ~[/itex] ?
You can ignore the additive constant and refer all energies relative to that value. |
| Oct17-07, 02:31 AM | #4 |
Yes, I figured it out. The problem was that I was under the false impression that I had to substitute epsilon for every x in that equation, which does not work.
I realized, however, that you can substitute for psi(x) separately since it is a factor on both sides of the equation. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: [SOLVED] QM simple harmonic oscillator
| [SOLVED] Simple Harmonic Oscillator | Introductory Physics Homework | 1 | ||
| Simple Harmonic Oscillator | Introductory Physics Homework | 0 | ||
| [SOLVED] Perturbation of the simple harmonic oscillator | Advanced Physics Homework | 4 | ||
| 1-D simple harmonic oscillator | Advanced Physics Homework | 3 | ||
| QM simple harmonic oscillator | Advanced Physics Homework | 0 | ||
