| Thread Closed |
Two Rotational Motion Questions |
Share Thread |
| Oct16-07, 09:12 PM | #1 |
The first one:
1. The problem statement, all variables and given/known data 1) A compact disc (CD) stores music in a coded pattern of tiny pits 10^-7 m deep. The pits are arranged in a track that spirals outward toward the rim of the disc; the inner and outer radii of this spiral are 25.0 mm and 58.0 mm , respectively. As the disc spins inside a CD player, the track is scanned at a constant linear speed of 1.25 m/s. What is the average angular acceleration of a maximum-duration CD during its 74.0-min playing time? Take the direction of rotation of the disc to be positive. 2. Relevant equations alpha_avg = (omega_2 - omega_1) / (t2 - t1) omega_inner = 50.0 rad/s omega_outer = 21.6 rad/s 3. The attempt at a solution I tried to take the average of the inner and outer angular velocities, and put that in for omega_2, and find the average that way, but I don't think I can do that. The second one: 1. The problem statement, all variables and given/known data 2) At t = 0 a grinding wheel has an angular velocity of 27.0 rad/s. It has a constant angular acceleration of 26.0 rad/s^2 until a circuit breaker trips at time t = 2.00 s. From then on, it turns through an angle 433 rad as it coasts to a stop at constant angular acceleration. At what time did it stop? 2. Relevant equations omega_2 = omega_1 + alpha * t delta_2 - delta_1 = omega_1 * t + 0.5 * alpha * t^2 3. The attempt at a solution I tried using a system of equations using the two equations above to solve for t, but I can't seem to get the right t value. Any guidance is greatly appreciated on either problem. Thanks in advance. |
| Oct17-07, 06:12 PM | #2 |
Recognitions:
For the first problem, your omega_inner and omega_outer look good to me. Why not just take (omega_outer - omega_inner)/(74*60)... that should be the answer.
For the second problem, think of the angular velocity and acceleration, just like kinematics formulas... What is the angular velocity at t = 2? Then you can use the equation, angle traversed = [(omega_1 + omega_2)/2]*t, so solve for how long it takes to go through the 433 rad... |
| Oct17-07, 10:09 PM | #3 |
Ok, thanks so much for your help. It makes more sense this way, than the way I initially tried to tackle the problems.
Thanks again :) |
| Thread Closed |
Similar discussions for: Two Rotational Motion Questions
| Rotational Motion Questions | Introductory Physics Homework | 13 | ||
| Rotational Motion Questions | Introductory Physics Homework | 2 | ||
| Rotational Motion and Moment of Inertia Questions... | Introductory Physics Homework | 7 | ||
| Rotational Motion Questions | Introductory Physics Homework | 1 | ||
| Rotational Motion Questions - Please Help | Introductory Physics Homework | 7 | ||
