Fixing the Timer1 Glitch - Moving a Picture Box on a Screen
The discussion focuses on resolving a glitch in a Visual Basic program that moves a Picture Box named "Robot" across the screen using a Timer control (Timer1). The primary issue arises from the incorrect handling of If statements and the misuse of the Robot.Left property, leading to unexpected behavior. The suggested solution involves restructuring the If statements to avoid nesting and incorporating Else statements for better control flow. Additionally, adding comments to the code is recommended for clarity and organization.
  • Understanding of Visual Basic programming
  • Familiarity with Timer controls in Windows Forms applications
  • Knowledge of event handling in Visual Basic
  • Basic debugging techniques for code optimization
  • Refactor the Timer1_Tick method to eliminate nested If statements
  • Implement Else statements to manage Robot movement logic
  • Add comments to the code for improved readability and maintenance
  • Explore Visual Basic debugging tools to identify and fix runtime errors
Visual Basic developers, software engineers working with Windows Forms, and anyone troubleshooting event-driven programming issues.
Marghk
Just have to get a picture box to move around a screen, I'm running the program by a timer. I'll show set integers below.
Timer = Timer1
Picture Box = Robot
Dim Robotpace as integer
Basically, when you click on the start button it enables the timer. Here's the coding.
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
RobotPace = 8
Robot.Left -= RobotPace
If Robot.Left <= 1 Then
Robot.Left = False
Robot.Top -= RobotPace
If Robot.Top <= 1 Then
Robot.Top = False
+ Robot.Left += RobotPace
+ If Robot.Left <= 1 Then
+ Robot.Left = False
End If
End If
End Sub
The lines with the (+'s) at the start of them are the beginning of the error. At this point, I'm aware that the timer mistakes the + and - statements in the Robot.Left movements and it completely glitches.
I just can't fix this.
Technology news on Phys.org
Hi there,
From what I can see, it looks like the issue might be with the placement of your If statements. You have an If statement nested within another If statement, and it may be causing the code to not execute properly. I would suggest rearranging the code so that the If statements are not nested, and also adding an Else statement to handle the case when the Robot.Left is not <= 1.
Also, it might be helpful to add some comments to your code to make it more clear what each section is doing. For example, you could add a comment above the line "RobotPace = 8" saying something like "Set the pace of the robot's movement" to help make your code more organized and easier to understand.
I hope this helps, and good luck with your project!
  • · Replies 25 ·
