Spinning the wheels: intro to angular momentum
The discussion focuses on calculating the angular momentum (L) of an object with rotational inertia (I) that starts from rest and rotates with a constant angular acceleration (α). To find the angular momentum after time (t), the relationship L = I(ω) is utilized, where ω (angular velocity) can be derived from the equation ω = αt. The discussion also touches on the concepts of torque (τ = rF) and the relationship between force and angular acceleration (F = mαr).
  • Understanding of rotational inertia (I)
  • Knowledge of angular acceleration (α)
  • Familiarity with angular velocity (ω)
  • Basic concepts of torque (τ) and force (F)
  • Study the relationship between angular velocity and angular acceleration
  • Explore the concept of torque in rotational dynamics
  • Learn about the conservation of angular momentum
  • Investigate applications of angular momentum in real-world scenarios
Physics students, educators, and anyone interested in understanding the principles of rotational motion and angular momentum calculations.
jaded18
An object has rotational inertia I. The object, initially at rest, begins to rotate with a constant angular acceleration of magnitude alpha. What is the magnitude of the angular momentum L of the object after time t?
___
So I know that I have to find angular velocity and use the equation
L=angular momentum= I(omega) ... so how do i find this omega in terms of alpha and t??
I know that torque = r*F and L = r*momentum ... and F=m(alpha)(r) ? ..
If it were a linear velocity problem, could you find the speed given acceleration and time? Use similar thinking.
ah that's too easy .. thanks lots:)
  • · Replies 17 ·
  • · Replies 35 ·
18K
