Parity Operator, Symmetric Potential: Is V=PV?
  • Context: Graduate
  • Thread starter Thread starter fantispug
    Operators Parity
The discussion centers on the relationship between the parity operator P and symmetric potentials V in quantum mechanics. It is established that while PV = VP holds true for symmetric potentials, the stronger assertion V = PV does not hold. The reasoning is grounded in the transformation properties of the operators, where P acts on the wave function and alters the potential accordingly. The conclusion emphasizes the need for clarity in operator definitions and their implications on wave function transformations.
  • Understanding of quantum mechanics and operator theory
  • Familiarity with the parity operator and its properties
  • Knowledge of symmetric potentials in quantum systems
  • Basic grasp of wave function transformations and linear operators
  • Study the mathematical properties of the parity operator in quantum mechanics
  • Explore the implications of symmetric potentials on wave function behavior
  • Learn about operator algebra and its application in quantum mechanics
  • Investigate the completeness and linearity of integrals in quantum operator theory
Quantum physicists, students of quantum mechanics, and researchers focusing on operator theory and symmetry in quantum systems will benefit from this discussion.
fantispug
Let's say we have a symmetric potential, in position representation [tex]V(x)=V(-x)[/tex] and let [tex]P[/tex] be the parity operator.
Then quite clearly [tex]PV=VP[/tex] but I was told the stronger statement [tex]V=PV[/tex] is not true, but I thought
[tex]V=\int_{-\infty}^{\infty} V\left|x\right\rangle\left\langle x \right| dx[/tex]
(where I have used completeness and linearity of the integral... though I'm having second thoughts about linearity - can I just move the integral through V?)
[tex]V=\int_{-\infty}^{\infty} V(x)\left|x\right\rangle\left\langle x \right| dx[/tex]
[tex]V=\int_{-\infty}^{\infty} V(-x)\left|x\right\rangle\left\langle x \right| dx[/tex]
[tex]V=\int_{-\infty}^{\infty} (PV(x))\left|x\right\rangle\left\langle x \right| dx[/tex]
[tex]V=\int_{-\infty}^{\infty} P(V(x)\left|x\right\rangle)\left\langle x \right| dx[/tex]
[tex]V=\int_{-\infty}^{\infty} P(V\left|x\right\rangle)\left\langle x \right| dx[/tex]
[tex]V=\int_{-\infty}^{\infty} (PV)\left|x\right\rangle\left\langle x \right| dx[/tex]
[tex]V=(PV)[/tex]
If V is not the same as PV, why not?
Cheers
If P acts like PV(x)=V(-x), then obviously PV=V for symmetric potentials, and your calculation was unnecessarily complicated. But I don't know how precisely your P is defined. Could it be, that it was defined so that it works like this PV(x)P^-1 = V(-x)?
hmh.. in fact this comes down to the question about what you want V to be. If you think that it is operator, that maps Psi into V*Psi, then PV=VP seems to be the only way.
In position representation V is an operator that maps the Psi like this
[tex] \Psi(x) \mapsto V(x)\Psi(x)[/tex]
Now you want to know what PV is. P maps the state V*Psi like this
[tex] V(x)\Psi(x)\mapsto V(-x)\Psi(-x)[/tex]
so, in other words
[tex] PV\Psi(x) = V(-x)\Psi(-x) = V(-x)P P^{-1}\Psi(-x) = V(-x)P\Psi(x)[/tex]
[tex] \implies PV(x)=V(-x)P \quad\Leftrightarrow\quad PV(x)P^{-1}=V(-x)[/tex]
Here the notation is bad, because it would be better to not have the (x) after the V, but its easier to write the operator V(-x) with this notation.
If you wanted to have PV=V, for symmetric potentials, this would imply
[tex] PV\Psi(x)=V(x)\Psi(x)[/tex]
which is wrong, because for symmetric potentials we have
[tex] PV\Psi(x)=V(x)\Psi(-x)[/tex]
Yeah, I realize my calculation was overly complicated, but I felt like I was trying to justify the obvious and didn't know how to do it.
That actually makes a lot of sense - I was thinking completely wrong about how the operators work (dropping the vector it operates on). It makes sense to me now: if you trasform a state psi by [tex]\psi\rightarrow P\psi[/tex], the states must transform as [tex]A \rightarrow P^{-1}AP[/tex] for consistency (which is the same as your expression for parity since the parity transformation is its own inverse)
Thanks for clearing it up.
  • · Replies 21 ·
  • · Replies 24 ·
  • · Replies 59 ·
  • · Replies 17 ·
