What is the connection between discrete torus geometry and lines on an NxN grid?
  • Context: Graduate
  • Thread starter Thread starter Galileo
    Geometry
The discussion revolves around the mathematical exploration of lines on an NxN grid, particularly in the context of discrete torus geometry. Participants are interested in generalizing the concept of lines in the plane R^2 to a finite grid structure, examining properties such as continuity across boundaries and the mathematical frameworks that may apply, including finite affine planes and their characteristics.
  • One participant seeks to understand how to define lines on an NxN grid and their properties, suggesting a connection to modular geometry.
  • Another participant proposes algebraic geometry or incidence geometry as potentially relevant fields for this inquiry.
  • Concerns are raised about the limitations of finite spaces, particularly regarding the uniqueness of functions defined on them.
  • A participant identifies the finite affine plane as a relevant structure, outlining its axioms and properties, such as the uniqueness of lines through distinct points and the existence of parallel lines.
  • There is interest in determining the conditions under which a finite affine plane exists, particularly questioning the case when N is not a prime power.
  • One participant suggests that any finite affine plane may be isomorphic to F^2 for some field F, proposing a proof based on this claim.
  • Another participant expresses skepticism about the completeness of this understanding, linking the problem to broader unsolved mathematical questions, including those related to mutually unbiased bases and projective planes.
  • The relationship between affine and projective planes is discussed, noting how they can be transformed into one another through specific operations.
Participants express a range of views on the properties and existence of finite affine planes, with some proposing specific mathematical frameworks while others highlight unresolved questions and complexities, particularly regarding non-prime powers. The discussion remains open-ended with no consensus reached on several key points.
Participants note that the existence of finite affine planes is well understood when N is a prime power, but remains largely unknown for other values of N. The discussion touches on unresolved mathematical steps and dependencies on definitions, particularly in relation to the properties of lines and points in finite geometries.
Galileo
I've come upon this situation in physics where I want to 'generalize' (or find some analog) of lines in a the plane R^2, to lines on an NxN grid of points, which would consist of a finite number of points on the grid.
The line should have the property that, if it goes off the boundary on one side, it will continue with the same slope on the opposite side. (Thus the space is like a 'discrete torus').
I`m think lots of mathematics has been done on this already, but I don't know what it's called. My first guess was modular geometry, but that didn't look like it. I don't want to waste time reinventing any wheels.
Any mathematician who can help me?
Algebraic geometry. Or maybe incidence geometry is enough, depending on your needs.
One of the problems with finite spaces is that there aren't enough "points" For example, in Z/2xZ/2, the functions
f(x) = x
f(x) = x^2
have the same graph.
What is your application?
f(x) = x
f(x) = x^2
Thanks.
Well in short, I have some real function defined on these NxN points, which resembles a probability density. I want to 'integrate' (sum) over a line in this space.
In a plane, this is straightforward, but how to define a line on this grid and what the properties are sounds mathematically interesting, but I've never encountered it.
Questions I think are interesting are:
- Given N, how many distinct lines exist?
- Given two distinct points, is there a unique line going through them?
How to characterize these lines and how notions like 'parallel' are carried over to this space may be important. Most things are probably straightforward, but I`m hoping there are some really nonintuitive theorems about this that may help me.
It turns out the finite affine plane was what I was looking for.
The axioms are:
(1) Given 2 distinct points there's a unique going through them
(2) Given a line and a point not on the line, there's a unique line parallel to the first
(3) There are 3 noncollinear points
(4) There are a finite number of points
And you can prove that there is a number n such that:
There are n(n+1) lines
Every points has n+1 lines going through it
Every line has n points
There are n^2 points
I want to work the other way around. I`m given n, so to say. So I'm interested in knowing for what n does a finite affine plane exist?
If n is a prime power, then you have the unique field of n elements F_n and F_n x F_n will work (like a 2d-vector space).
But what if n is not a prime power? Is there anything known about it?
I suspect that you can prove that any finite affine plane is isomorphic to F^2 for some field F, and therefore you have described the entire collection.
If my claim is true, the proof would probably look very much like the proof that the Euclidean plane is isomorphic to R^2. I can give a try at the proof if you don't want to work on it first. (Or try to look it up)
I'd be happy if you want to try it, Hurk. But before you may go on a wild goose chase;
I`m not sure about this, but from bits and pieces I've gathered it seems that this is still a very big unsolved problem in mathematics. And I've a hunch it's very deeply related to the problem of finding N+1 mutually unbiased bases in an N-dimensional Hilbert space and finding N-1 orthogonal latin squares of order N. (Very likely it's also related to finding for what order N projective planes exist, but I know next to nothing about those.)
Not only is the existence known when is N a prime power. It is largely unknown when N isn't a prime power. I will try to find more on it and see what the connections are.
I appreciate the input.
I find that plausible too -- I remember that coordinates make sense for any affine plane, but not if we can assume the # of points on a line is a prime power.
It's certainly related to projective planes; if you remove a line (and the points on it) from a projective plane, you are left with an affine plane. Conversely, any affine plane can be extended to a projective plane by adjoining a point of intersection for each class of parallel lines, and the line at infinity that passes through all of them them. (And these operations are inverses)
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 32 ·
14K
