Prove f is Constant Function on U
  • Thread starter Thread starter littleHilbert
    Constant Function
The discussion revolves around proving that a differentiable function \( f: U \longrightarrow \mathbb{C} \) is constant on an open, path-connected subset \( U \subset \mathbb{C} \) given that its derivative \( f'(z) = 0 \) for all \( z \in U \). Participants explore the implications of the hypotheses and the properties of complex differentiability.
  • Participants discuss the use of paths in \( U \) to show that \( f \) is constant between any two points. There are mentions of using the Fundamental Theorem of Calculus for path integrals and the implications of \( f' \) being zero.
Several participants have provided insights and attempted to clarify the reasoning behind the proof. There is an ongoing exploration of whether the arguments presented are sufficient or if additional methods, such as path integrals, should be employed. No explicit consensus has been reached, but productive dialogue continues.
Participants are considering the implications of differentiability and the properties of holomorphic functions within the context of the problem. There is an emphasis on ensuring that the arguments are rigorous and formally presented.
littleHilbert
Please check whether this makes sense
If [itex]U\subset\mathbb{C}[/itex] open, path-connected and [itex]f:U\longrightarrow\mathbb{C}[/itex] differentiable with [itex]f'(z)=0[/itex] for all [itex]z\in{U}[/itex], then f is constant.
Hypotheses:
H1: U is pathconnected
H2: [itex]f:U\longrightarrow\mathbb{C}, f'(z)=0, z\in{U}[/itex]
2. The attempt at a solution
By H1 for every [itex]p,q\in{U},p\neq{q}[/itex] there exists [itex]\gamma:[a,b]\longrightarrow{U}[/itex] such that [itex]\gamma(a)=p,\gamma(b)=q[/itex].
So let [itex]\gamma[/itex] be an arbitrary path in U and let [itex]z\in\gamma([a,b])\subset{U}[/itex], that is [itex]z:=\gamma(t)[/itex] for [itex]t\in[a,b][/itex].
We shall show that f is constant on any path in U between arbitrary but fixed points p and q. Since [itex]\gamma[/itex] is arbitrary, it will then follow that f is constant on U.
Since f is complex-differentiable and gamma is continuous, and hence also real-differentiable, we have [itex](f\circ{\gamma})'(t)={\gamma}'(t)f'(\gamma(t))[/itex]. But [itex]f'(\gamma(t))=f'(z)=0[/itex] by H2, hence [itex](f\circ{\gamma})'(t)=0[/itex], which implies that [itex](f\circ{\gamma})(t)=const[/itex]. In particular, [itex](f\circ{\gamma})(a)=(f\circ{\gamma})(b)[/itex], that is [itex]f({\gamma}(a))=f({\gamma}(b))[/itex], or [itex]f(p)=f(q)[/itex] for all [itex]p\neq{q}, p,q\in U[/itex]. But this is exactly the property of a constant function. It follows that f is locally, on a subset of U, constant and hence constant.
littleHilbert said:
...hence [itex](f\circ{\gamma})'(t)=0[/itex], which implies that [itex](f\circ{\gamma})(t)=const[/itex].
But could you prove this?
My hint at the solution to the problem would be: path integrals.
Yes, I think I can.
We have [itex](f\circ{\gamma})'(t)=u'(t)+iv'(t)=0\Longrightarrow{u'(t)=0=v'(t)}[/itex], which means that [itex]u(t)=C_1, v(t)=C_2[/itex] are constant functions and so [itex](f\circ{\gamma})(t)[/itex] is constant.
Must I use path integrals here. Is the above argumentation incorrect or imprecise?
Ok, now it looks good and complete!
(But with path integrals it is very fast: "Let a,b be in U and y be a path in U joining and and B. Then by the FTC for path integrals in the complex plane, the integral of f '(z) along y is both 0 and f(b)-f(a). Therefor f(b)-f(a)=0. QED)
Ok, I'll try to go into detail, because I'd like to write it down formally and clearly.
So you say that:
Constant functions are trivially continuous and holomorphic everywhere in C. U is open, so f' is holomorphic on U. Also the path gamma is continuous and hence smooth. These two statements imply that a primitive of f' on U exists and is determined up to a constant. Clearly, f' has a primitive on gamma.
Let F be a primitive. Again, differentiability of f implies that primitive F is holomorphic and F=f.
Now we apply the FTC to any path gamma between any two points a and b to conclude that:
[itex]\displaystyle\int^{}_{\gamma} f'(z)\,dz = f(b)-f(a)[/itex]
At the same time: [itex]\displaystyle\int^{}_{\gamma} f'(z)\,dz = 0[/itex] by hypothesis. Hence f(b)=f(a) for all different a and b in U. Thus it follows f is constant.
Is it OK?
Many thanks in advance
So you say that:
Is it OK?
Yes.
  • · Replies 36 ·
