Calculating Particle Velocities in a Relativistic System
The discussion revolves around calculating the velocities of two particles in a relativistic system, specifically in the context of an accelerator where the particles approach each other at a relative speed of 0.880c. Participants are exploring the transformation of velocities and the definitions of various terms used in relativistic equations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of the velocity transformation equation and question the definitions of variables involved in the relativistic context. There are attempts to clarify the relationships between different frames of reference and how to apply the equations correctly.
The discussion is active, with participants providing insights and clarifications regarding the definitions of variables and the application of relativistic equations. Some participants express understanding and seek further clarification on the concepts presented.
There is a noted confusion regarding the interpretation of relative speeds and the definitions of variables in different frames of reference. Participants are also addressing potential contradictions in the statements made about the velocities of the particles.
Niles
I have two particles in an accelerator approaching each other with a relative speed of 0.880c. The particles travel at the same speed as measured in the laboratory. I have to find the velocity of each particle.
Ok, I use the transformation of velocities:
u'_x = (2*0.880c)/(1-(-(0.880c)^2/c^2)
- since v_1 = -v_2. I get 0,99c, but apparently it must equal 0,597c?!
You're using that equation backwards. That equation gives you the relative speed, which you already have, in terms of the lab frame speeds.
Can you tell me, what u'_x, v and u_x are? They seem to differ (the meaning of them) every time I encounter a new problem.
v is the speed of object u' relative to u, and u_x is speed of u to stationary observer and u'_x is speed of u' to stat. obs.?
This doesn't add up with our problem? (Btw, I got the real answer, but I still lack the definitions).
Here's one way of looking at it. In the lab frame, the velocity of the A particle is +u and the B particle is -u. From the frame of the B particle, the lab frame is moving at speed +u. (Call the lab frame S', since it's moving.) So, in the lab frame the speed of the A particle is u' = u.
Transforming to the stationary frame of the B particle, the speed of the A particle with respect to the B particle will be given by:
v = (u' + u)/(1 + u'u/c^2) = 2u/(1 + u^2/c^2)
Make sense?
One way I like to write this is:
Relativistic addition of parallel velocities:
[tex]V_{a/c} = \frac{V_{a/b} + V_{b/c}}{1 + (V_{a/b} V_{b/c})/c^2}[/tex]
Ahh, I see.
Can you tell me more generally, what they stand for? So I can use them on other examples.
But I liked your explanation! (bookmarked)
What what stands for? Which variables do you mean?
What u_x, u´_x and v stand for in the equations when transforming velocities.
u_x is the speed of the object as seen from a stationary observer?
v is the speed of S' relative to S?
u´_x is the speed of the object in S' as seen from a stationary observer?
How about this:
u_x is the speed of object as measured in frame S (stationary)
u'_x is the speed of object as measured in fame S' (moving)
v is the speed of S' as measured in frame S
In that case:
u'_x = (u_x - v)/(1 - v u_x/c^2)
Let me know if that makes sense to you.
Applying this version to your problem:
Speed of A in S = + .88 c
Speed of B in S = - .88 c
If you choose a frame S' moving along with A (say), then v = +.88 c. Then you use the above formula to transform the speed of B in frame S (u_x = -.88 c) to find its speed u'_x with respect to A (which is S').
I found an example in my book that I tried to solve, which I hope will clarify things for my, but I'm kinda stuck.
"A planet P between two rockets A and B wants to measure the velocities of A and B. P is watching A and B getting closer to each other, and the distance between them is getting smaller with the velocity (5/7)c. From A it looks like B is approaching A with the velocity (35/37)c."
Ok, first of all, we notice that A and B are getting approaching each other with the velocity (5/7)c, so:
(5/7)c = (u_a + u_b) / (1+u_a*u_b/c^2).
Also, from A it looks that B's speed is (35/37)c, so:
(35/37)c = (u_a + u_b) / (1+u_a*u_b/c^2).
Am I way off here?
This is a tricky one! First note that the highlighted statement is not equivalent to:
Which is good because this equation:
so:
Directly contradicts the other one.
Instead, it means that as seen by P, the distance between A and B is decreasing at a rate of (5/7)c. That's equivalent to saying that: (5/7)c = u_a + u_b
Good.
Now combine the two equations to solve for the speeds.
Ahh, I see.. I think I'm getting the hang of this.
Thank you for all your help so far.
