Why Is Leakage Flux Represented by an Inductor in Transformer Models?
The discussion revolves around the representation of leakage flux in transformer models, specifically why it is modeled as an inductor. Participants explore the nature of leakage flux and its implications in transformer operation.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant notes that leakage flux is the portion of the flux from the primary winding that does not couple to the secondary winding.
  • Another participant suggests that without the secondary winding, a transformer behaves like an inductor.
  • A different participant mentions the practical aspect of using a transformer style due to the large value of the required inductor.
  • A question is raised about the use of a one-to-one transformer, to which a brief response indicates isolation as a reason.
Participants express varying levels of understanding and inquiry regarding the representation of leakage flux, with no consensus reached on the underlying principles or implications.
Some assumptions about the definitions of leakage flux and transformer behavior may not be fully articulated, and the discussion does not resolve the complexities of these concepts.
scothoward
Hey, I am currently reading about transformers and one aspect of the equivalent circuit that I do not understand is why the leakage flux is represented by an inductor? Any help on this would be much appreciated.
Thanks!
Leakage flux is just the portion of the flux generated by the primary winding that does not couple to the secondary winding of a transformer. Without the secondary winding (or if the secondary winding is not connected) a transformer is just an inductor.
I just need a inductor,but the its value is large,so the manufacturer suggest to make a transformer style instead.So the theory told above is right.Thanks!
Why we use a one-to-one transformar
Isolation.
  • · Replies 36 ·
13K
  • · Replies 26 ·
  • · Replies 79 ·
