Simple Moment of Inertia and uniform bar problem
The discussion focuses on calculating the moment of inertia for a uniform bar with two point masses attached at its ends. The bar is 2.00 m long with a mass of 4.00 kg, and each ball has a mass of 0.500 kg. The calculations for the moment of inertia about various axes were performed using the formulas I=Σmiri2 and IP=ICM+Md2. The results obtained by the user for parts (a) through (d) were 2.33 kg m2, 7.33 kg m2, 0 kg m2, and 1.25 kg m2, respectively, which differ from the textbook answers.
  • Understanding of moment of inertia concepts
  • Familiarity with the parallel-axis theorem
  • Knowledge of basic physics equations for rotational motion
  • Ability to perform calculations involving mass and distance
  • Review the derivation of the moment of inertia for a slender rod
  • Study the parallel-axis theorem in detail
  • Practice additional problems involving point masses and rigid bodies
  • Explore the differences between point mass and distributed mass calculations
Students studying physics, particularly those focusing on mechanics and rotational dynamics, as well as educators seeking to clarify concepts related to moment of inertia.
GoldShadow
Problem reads:
"A uniform bar has two small balls glued to its ends. The bar is 2.00 m long and has mass 4.00 kg, while the balls each have mass 0.500 kg and can be treated as point masses. Find the moment of inertia of this combination about each of the following axes:
(a) an axis perpendicular to the bar through its center; (b) an axis perpendicular to the bard through one of its balls; (c) an axis parallel to the bar through both balls; (d) an axis parallel to the bar and 0.500m from it.
[tex]I=\sum m_{i}r^{2}_{i}[/tex]
[tex]I_{P}=I_{CM}+Md^{2}[/tex]
Moment of inertia for a slender rod, axis through center: [tex]I=\frac{1}{12}ML^{2}[/tex]
Moment of inertia for a slender rod, axis through one end: [tex]I=\frac{1}{3}ML^{2}[/tex]a) To find total moment of inertia, I used the equation [tex]I=\frac{1}{12}ML^{2}+2m(\frac{L}{2})^{2}[/tex], where "m" is the mass of one ball, "M" is the mass of the rod and "L" is the total length of the rod: [tex]I=\frac{1}{12}(4.00kg)(2.00m)^{2}+2(.500kg)(\frac{2.00m}{2})^{2}=2.33 kgm^{2}[/tex]
b) For this part I used [tex]I=\frac{1}{3}ML^{2}+mL^{2}[/tex], since one ball is on the axis of rotation and does not contribute to the moment of inertia. The answer I got:
[tex]I=\frac{1}{3}(4.00kg)(2.00m)^{2}+(.500kg)(2.00m)^{2}=7.33 kgm^{2}[/tex]
c) Zero, since the rod/balls are not given a radius; their distance from the axis of rotation is zero.
d) Using the parallel-axis equation, [tex]I_{P}=I_{CM}+Md^{2}[/tex], I had 0 for [tex]I_{CM}[/tex] as found in part C, 5.00 kg for "M" (total mass of rod and balls... or do I add each separately?) and .500m for "d" as given in the problem. My equation/answer:
[tex]I_{P}=(0)+(5.00kg)(0.500m)^{2}=1.25 kgm^{2}[/tex]
The answers in the back of my textbook are not only incomplete, they seem incorrect and I would appreciate any help. Thanks.
EDIT: I don't think I'm actually supposed to use the "parallel axis" equation in this problem on second look, so I'm positive I did part D wrong... but I'm still not entirely sure about parts a-c.
Your answers look right to me (including d)... what are the answers in the back of the book?
The book says (a) is 0.0640, (b) is 0.0320, (c) is 0.0320 (all in kg m^2), and it doesn't give an answer for (d).
  • · Replies 21 ·
