Tension on a Frictionless Surface
The problem involves a 20 kg block being dragged across a frictionless surface by a steel cable under the influence of a 100 N force. The objective is to determine the mass of the cable based on the given conditions.
  • Participants discuss using kinematic equations to find acceleration and analyze forces acting on both the cable and the block. There are considerations about the net forces and tension in the cable, as well as questioning the role of gravity in the scenario.
Some participants have offered insights into the forces at play and suggested methods for calculating acceleration. There is an ongoing exploration of the forces acting on the cable and block, with no explicit consensus reached yet.
Participants express uncertainty about the number of forces acting on the cable and the implications of gravity in the context of the problem. The original poster seeks guidance without requesting direct answers.
JeYo
A massive steel cable drags a 20 kg block across a horizontal, frictionless surface. A 100 N force applied to the cable causes the block to reach a speed of 4.0 m/s in a distance of 2.0 m.
What is the mass of the cable?
I hate to ask you folks for a lot of help. But I have no idea of how to solve this problem, or of how to approach this problem. If anyone could I would love a little push in the right direction but I definitely am not asking for the answer.
[tex]v_{x}^{2}=v_{0x}^{2}+2a_{x}(x-x_{0})[/tex]
solve for acceleration
draw two your force diagrams
[tex]\Sigma{F}=ma[/tex]
Well, I was thinking about it by looking at the net forces of the rope and the block separately.
For the rope, there is a 100 N force rightward and a T force leftward. The addition of these forces equals ma.
Looking at the block, there is a tension force rightward which should equal the rope's tension force leftward. You can find that tension because you have the mass of the block and can find its acceleration. You can probably take it from there.
Does that make sense to you?
I realize that the acceleration is 4.0m/s/s; however, I wonder if there are more than two forces acting on the cable. I mean, there is the F(b on c) and the F(G).
The force of gravity does not contribute to the acceleration.
Thank you all very much, you were all very helpful.
  • · Replies 24 ·
  • · Replies 19 ·
